Hi All,
I was wondering what the dimension(s) is/are for the M60 with motor mounts for an E30 from center of bottom hole in motor mount arm (where the rubber mount bolts in) to opposite hole? in other words, the width across the arms where the rubber mounts bolt to.
On a stock setup, they are close to 20".
Also, what is the distance between the mounting holes on the subframe in the E30?
My swap is not going into an E30, but I was wondering how close they are to my car, as I would rather buy the mounts since they're available (if they'll work).
Clear as mud?
Thanks!
Clear as mud?
Thanks!
