530i 5speed torque specs?
    Looking to do a m60 swap,will the 5speed from a 530i handle the torque, will the flywheel clutch setup work? Is there a driveline setup that will work without going with a custom driveline. Found a trans locally just wanted some input before i pick it up.
    yes.
      That's been gone over extensively in this sub forum. I'd recommend searching a bit and reading over the discussions so that you can select the parts that suit your needs.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
