If you already have the obd1 harness, get new obd1 sensors to match. They made 2 pin and 3 pin OBD1 knock sensors.
M60b44 #
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
Ok I got the right harness now, just a matter of time now (literally like 2 hours)Comment
Btw is there a neutral safety which we have to wire up on the auto harness?? For it to turn over?Comment
It's coming along guys
[/URL]
So I bled the brakes, and I should have listen to all of the notice's that said don't use the 3/8 master cylinder for the clutch. Cause I went ahead an bled it and yeah....no go. So that's the hold up at the moment but everything is a goComment
You went 3/8"? I thought most guys are going 3/4"?Comment
Ah gotcha. I think I remember seeing a build where they ran into the same problem. They fixed it by returning the 5/8" for the 3/4" on the clutch.
Sweet build BTWComment
Sweeet... that was my guess, but I wasn't familiar enough with car or engine to be sure.
Yours?
You like DIY V8 2 seaters, eh?Comment
