M60b44 #
  • george graves
    • 19997
    #196
    Sounds mean!!!!
    Originally posted by Matt-B
    • JCarp90
      • Feb 2011
      • 1759
      #197
      Got to hear this beast fire up this weekend. It's going to be a fuuuuuuuun summer.
      • Vtec?lol
        • Dec 2009
        • 3278
        #198
        How are you going to be tuning this?
        • driftingminor913
          • Sep 2011
          • 358
          #199
          Stock DME
          Because V8
          http://www.r3vlimited.com/board/showthread.php?t=282219
          Doing it wrong since 91:wgaf:
          • Vtec?lol
            • Dec 2009
            • 3278
            #200
            404 DME? Aftermarket chip?
            • driftingminor913
              • Sep 2011
              • 358
              #201
              I'm sorry for the lack of updates I have been really busy with a new welding job n boy my boss I swear is the hardest person to impress...and he builds nothing but big blocks. So when I told him what I was building he laughed at me...until I said I could add a snail to it hehehehe
              But anyway I have just been tiding up the loose ends and getting this thing ready for a big local meet coming up here in Kansas City.
              Got this in the mail this evening, no power steering or brakes and a 4.10LSD man this is going to be one hell of a daily in the summer
              Because V8
              • driftingminor913
                • Sep 2011
                • 358
                #202
                All that's really left now, is a temp sensor (sender), add coolant, finish making a overflow tank since I don't wana drag a hose all the way to the battery box to use the OEM 325i one. Also buy O2 sensors, accelerator bracket, make intake and add coolant and go for a test drive. Btw talk to my tuner this past weekend an we looked over the car n everything is a go for tuning, he actually couldn't beleive I stuffed the M60 in there hahaha..but I will keep you guys updated as much as possible
                Because V8
                • P Arkus
                  • Dec 2012
                  • 325
                  #203
                  Sorry please correct me if I'm not understanding this right....you're running no power steering, manual brakes, and a 4.10 with a 5spd??? Is this going to be a track car or DD? Also what steering rack are you running?
                  Like you say this car is going to be fun in the summer
                  Originally posted by 36brua
                  Isn't that what these forums are all about making stuff easier... OO no never mind this is r3v...
                  Patryk:up:
                  Instagram: @parkus08
                  91 BMW 325is ///M-Tech II
                  08 VW .:R32
                  04 Audi A4 Avant 1.8TQ
                  • MattAvino
                    • Jan 2011
                    • 2147
                    #204
                    Awesome work. I really like the log headers.
                    E30 buildy things
                    http://www.r3vlimited.com/board/showthread.php?t=195286
                    • driftingminor913
                      • Sep 2011
                      • 358
                      #205
                      Yes, yes, yes and yes. And a little bit of both, figured I see what happens but the whole point is to provide information about the whole "Hybrid Debate" which is why their reall won't be any videos till it's on the dyno...a before tune and after tune
                      Because V8
                      • driftingminor913
                        • Sep 2011
                        • 358
                        #206
                        Thank you, I wish I could do it again now that my TIG skills are far beyond what they were when I did those haha
                        Because V8
                        • JGood
                          • Jan 2004
                          • 7959
                          #207
                          The only thing that bothers me about any dyno results is your log manifolds. They are the worst type of manifold. And the fact that they feed a 2" down pipe instead of 3" or even 2.5", that's going to be a bottleneck I'd think.
                          The factory manifolds aren't great, especially the m62tu manifolds that most of us use, but at least BMW paired the cylinders for pulse tuning so there isn't cylinder pulse collisions all over the place like in a log manifold. They are actually a 4-2-1 design, you can see that if you cut one open, which is definitely good.
                          Not knocking your work, they look great, I'm just curious, and maybe a little skeptical, of how the flow compares to the factory manifolds. A lot of engineering goes into header design, there's a ton of math that needs done to be able to design something that maximizes flow, and it's easy to mess it up and really inhibit flow.
                          Did you ever finish your exhaust system? I remember your drivers side down pipe being really close to the ground, just wondering how you're doing on ground clearance. I know mine drag all over the place and I have mine tucked almost against the body, it's a PITA.
                          e30 restoration and V8 swap
                          24 Hours of Lemons e30 build
                          • The Dark Side of Will
                            • Jun 2010
                            • 2796
                            #208
                            Am M60B44's no 572 or 632, but the E30's a light car and it'll still be pretty quick. Should be mid-low 12's if you can get traction.
                            My dad talks about Corvettes in the 60's, with 350 HP 327 engines, 4 speed transmissions and optional 4.10 gears. RPM limited at 120, but ridiculous acceleration at highway speeds.
                            You may end up stepping off in 2nd most of the time, because the engine will have MORE than enough torque to do that without any problems.
                            You might want to look into a 2.93 or 2.79 LSD from a 325e, though. The ZF has a 4.20 first gear, so you don't need much gear out back to pull hard in 1st.
                            • Vtec?lol
                              • Dec 2009
                              • 3278
                              #209
                              I'f I could find one, I would go 2.79
                              • irrelevante30
                                • Apr 2013
                                • 100
                                #210
                                just read through this whole thread. Great work man! Those headers look pretty simple and effective. where did you get the piping to make them? approx cost?
                                also, i didn't see on your posts, but what clutch are you running with that 530i flywheel? from the ebay screenshot, looked like it said 330i? couldn't see exactly though...
                                good work man, keep it up!
