M62 Non-Vanos (96/97/98) EWS options
  • NSBMW
    • Dec 2012
    • 10
    I've been looking for a way to remove EWS from the DME for a while but I can't seem to find anything. What are the options for removing EWS?
  • alco
    • Feb 2013
    • 197
    I'm in the same boat. Best option at this point may be these guys out of Canada
    RPM Motorsports: http://rmsonlinestore.com/
    Not sure what all they can do, or what DME's they work with. Their eBay auction shows one thing and the site seems to talk about something else. Give them a call or email them?
    I'm subscribing because I'm in the same boat. Jonsku may have worked around it or he may have swapped over the keyring, EWS module and DME all together. Not sure how he did it, maybe he can chime in.
    Also there is another user on here, the spelling of his name escapes me right now but he also claims to have a solution. I've made contact with him and it's been slow progress thus far. My second message has been responded to, just waiting now. I'll shoot RPM an email as well. This is the biggest stumbling block for my build as well. Most of the parts have been sourced and I'm hoping to be able to get time to remove the old M20 and finally get working! Maybe we can help each other, if you figure it out first, let me know and I'll do the same for you. Thanks.
    Velocity Motor Works
    1972 2002
    1983 533is
    1987 325is (Roxanne)
    1988 M6
    1989 M3
    1989 325ix (Darth Maul)
    Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
    • alco
      • Feb 2013
      • 197
      Another alternative is to use an older harness (have not found solid documentation on what needs to be changed for this) and DME but I'm not sure how one would account for the additional .4 liters of displacement. But that has been done as well. I personally am not a fan of the swapping of motor parts even though others have done it.
      1972 2002
      1983 533is
      1988 M6
      1989 M3
      • alco
        • Feb 2013
        • 197
        Here is the RPM Motorsports part: http://www.rmsonlinestore.com/BMW-Un...-Bypass_c7.htm
        1972 2002
        1983 533is
        1988 M6
        1989 M3
        • alco
          • Feb 2013
          • 197
          Contacted RPM and they said they can do it although there is about an 8 day wait period at this time. More to come.
          1972 2002
          1983 533is
          1988 M6
          1989 M3
          • alco
            • Feb 2013
            • 197
            RPM says $849 to do the software mods to remove EWS...
            1972 2002
            1983 533is
            1988 M6
            1989 M3
            • NSBMW
              • Dec 2012
              • 10
              Shit, I forgot about this thread. We haven't put the engine in yet still acquiring parts. I appreciate your responses though, I looked at RPMs stuff a little while back and noticed they sell the whole DME/EWS package. To be honest it's cheaper($600) than deleting the EWS at $900:O
              Not sure what I will go with yet, I've contacted so many tuners who said they couldn't do it, at least I found someone now I guess, and I'm in Canada too so maybe I get a fellow Canadian discount :rollseyes
              Thanks for the responses, keep me updated on what you plan to do!
              • alco
                • Feb 2013
                • 197
                No problem. The question then is what ECU is pin for pin compatible in place of the 284 ECU? With that knowledge, there is no need to spend the higher dollar figure.
                1972 2002
                1983 533is
                1988 M6
                1989 M3
                • NSBMW
                  • Dec 2012
                  • 10
                  Well hopefully I can grab a 284 with all the EWS equipment attached. What I really need is a 540i parts car from the m62NV era. But as we both know those are few and far between.
                  • alco
                    • Feb 2013
                    • 197
                    Indeed. RPM doesn't sell the 284 DME without EWS. You can get the DME and key and ring here right now:
                    http://www.ebay.com/itm/111045527635...84.m1438.l2661
                    I have no affiliation with the seller, stand to gain nothing, cannot vouch for him/her. It's just something I found in my search.
                    Personally because I don't want EWS getting into the mix at all. So I will continue to look for an alternative until I can't find one.
                    1972 2002
                    1983 533is
                    1988 M6
                    1989 M3
                    • NSBMW
                      • Dec 2012
                      • 10
                      Did any of the e39 v8s come with EWS2? My engine is a 96 m62NV which I'm guessing originally would have had EWS2? I'm just thinking that ews2 DME probably is a Non Vanos DME and probably the one I need.
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5248
                        Anyone know if MMW does flashes for m62/m62tu ews delete?
                        Originally posted by priapism
                        Originally posted by shameson
                        • NSBMW
                          • Dec 2012
                          • 10
                          I've emailed him (Dave) several times, but no response although I have a suspicion he can or is "close".
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Im soooo far behind :(. It is near the top of my list. If i can get it sorted by my contacts ill spend the time to do it myself. Ive got 2 M62NV's here w/ECUs/harnesses and an E30 shell one of them is destin for.
                            Check Us out on Facebook
                            Full Product Line Tuning
                            • alco
                              • Feb 2013
                              • 197
                              I managed to find a 96 M62B44 harness on eBay that looks like it'll take the 474 ECU which can be had from RPM with EWS deleted for a lot less than having them rework the 284 DME...
                              1972 2002
                              1983 533is
                              1988 M6
                              1989 M3
