Junkyard M60B40, thoughts? (pics)
  • noid
    • 1536
    Had a local-ish junkyard send me pictures of an m60 they have that they are selling for a tempting price. Engine has ~120 miles and came from a 94 740i.
    These are the pictures they sent me, they are fairly poor pictures but still worth getting an opinion here before I make the drive to get it:
    Thoughts?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • The Dark Side of Will
    • Jun 2010
    • 2796
    Assume you mean 120 miles...
    Was nikasil used as late as '94?
    In the second pic it looks like the harness has been cut a bit.
    • MJCRO
      • Apr 2012
      • 597
      Seems pretty clean. But yeah, it looks like the harness for the ECU has been cut. What's the asking price?
      • Vtec?lol
        • Dec 2009
        • 3278
        Compression and leak down test are in order first.
        I only buy motors that I can see and hear running.
        • slammin.e28
          שמע ישראל
          • 12054
          Serial #s on the side of the block. Any mention of them? They will tell you, as I'm sure you know, Nikisil vs Alusil.
          I'd probably get them to do a leak down test, and maybe even see if you can't get a boroscope down the spark plug tubes to check it out. That is, all after you verify alusil vs nikisil....although it is kind of a moot point by now. If a nikisil has been running this long, it's probably good.
          Having ~120 miles, if true, could mean it was a warranty replacement alusil engine for the campaign against nikisil, so it could be very good.
          • cabriodster87
            • Jan 2011
            • 1042
            Copied from: http://www.e38.org/koalamotorsport/v8shortblock.htm
            Nikasil M60B30 1 725 970 or 1 741 212
            Nikasil M60B40 1 725 963 or 1 742 998
            Alusil M60B30 1 745 871
            Alusil M60B40 1 745 872
            Alusil M62B44 1 745 873 NOTE, all US market M62 engines are Alusil.
            This is the only way to determine which M60 you have, short of removing a cylinder head.
            Reich und Roll!
            • Jean
              • 18228
              Looks like 100 other m60b40s from a junk yard... you can't tell anything from pictures.
