And yet another V8 swap...
  • Yorl
    • Mar 2012
    • 172
    #31
    • evandael
      • Oct 2009
      • 2881
      #32
      this is a really cool build. i'm very interested in the ITBs/engine management/etc.
      are you considering a M60B44 hybrid? ain't no replacement for displacement..
      • Yorl
        • Mar 2012
        • 172
        #33
        For now I'll stick to the B40 with increased compression and the cams. I have a thing with short stroke engines... We'll see when it's running. As long as it performs better than my old setup, it'll be good.
        • The Dark Side of Will
          • Jun 2010
          • 2796
          #34
          IDF stacks work on the S62 ITB's? That's convenient.
          • Yorl
            • Mar 2012
            • 172
            #35
            Yup, same bolt pattern and diameter
            • bimmerteck
              • 762
              #36
              Looks like a solid build in the works, I look forward to seeing the results.
              • Yorl
                • Mar 2012
                • 172
                #37
                Thanks! It's gonna take some time, I spend all day working on other people's project cars cars, so mine has to wait...
                • Yorl
                  • Mar 2012
                  • 172
                  #38
                  Bit of an update, not much though....
                  Decided to attack the wiring harness, as I will be changing everything...
                  There, fixed....
                  Today we scrapped an S60R at work (one of our spare shells), and it kindly donated a few parts I will re-use.
                  Fusebox:
                  Power steering cooler:
                  And, I forgot to post the flywheel I'll be using
                  This weekend I should be starting with the new wiring harness (body harness), new fusebox and relaybox inside the car (away from the heat), and with a much simpler design. After that, I will do an independent harness for the engine. It's a lot of work, but that's what I'm used to do, so....
                  • airkhin
                    • 593
                    #39
                    cant wait to see more updates on this build. looks great so far!
                    • iansane
                      • 1342
                      #40
                      For those wheels, you've swapped the fronts and rears correct? (You're running the ones labelled front on the rear and vice versa?
                      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                      • Yorl
                        • Mar 2012
                        • 172
                        #41
                        Yes, et0 (fronts) are on the back, and the et16 are on the front.
                        • Yorl
                          • Mar 2012
                          • 172
                          #42
                          So I started working on the interior while I wait for the engine work to be finished.
                          I started fabricating a new wiring harness with "oh surprise"... CONNECTORS!! I hate how stupid a one piece harness is... I just hate it. So now I'm re-wiring everything, each system labeled and independent from one another.
                          Fuel tank wiring and all the wires for rear lights and central locking, with connectors on the B-pillar
                          All the crap in the transmission tunnel is gone, I'm just keeping the electric windows switches, also with shorter and independent wires.
                          I should have pictures of the finished result somewhere though...
                          Now, interior coming back together!!!
                          Old carpet
                          It was pretty disgusting, wanted to get a black one but it wasn't easy, but I found a post talking about the dupli-color spray paint for interiors and decided to give it a try (couldn't be worse....)
                          It used three cans of the thing, and it looks great. It's not hard to the touch, I was really impressed.....
                          Anyway, now the dash is "almost" on, windows and sunroof are wired, central locking, mirrors and interior lights.
                          I now have to find a nice spot for the new fusebox and finish off the wiring for the interior.... yay
                          • jalopi
                            • 2370
                            #43
                            [/quote]
                            Holy crap man... how much does that flywheel weigh??? That's not one solid piece of metal is it???
                            • Yorl
                              • Mar 2012
                              • 172
                              #44
                              Nopes, it's not solid!!! And it's 17 pounds
                              • Northern
                                • 5128
                                #45
                                where'd you source that?
                                Originally posted by priapism
                                Originally posted by shameson
