From Boost to Reliable. M62b44 Swap!
  • MonkeyMadness
    • 3251
    wow. look good so far.. Interested in the out come!
    • The Dark Side of Will
      • Jun 2010
      • 2796
      A benefit of doing the M60 top end conversion is the idler style timing drive that doesn't use the idiotic U-guides.
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        Sub'd for V8 fun :)
        • jharrel
          • Aug 2012
          • 130
          nice this thing is going to be fun
          • Zacm829
            • Jan 2008
            • 1919
            Well over the holiday I moved to motor to its final swap location and helped lay down some for concrete to aid in the swap.
            Right before I packed up the motor for its ride to Columbia, SC
            With the help from my roommate we were able to shoehorn the m62 into the back of my wrangler. Rode pretty well and helped with some traction off road! :)
            Was also able to squeeze all of the swap parts into these two bins for better storage and transport.
            Arrived at Mattdk's house and unloaded the motor while his m5 looks on, he also has a massive dog.
            The next day we poured and finished 5 yards of concrete at his house to prepare for an enclosed carport that will give him extra room for his plasma table and room to work on the e30 swap.
            Also had the m62 injectors sent to Marksinjection to be cleaned and refreshed. Great price and quick turnaround!
            Next steps will be to replace the timing chain guides and put on the water pump. Then we will move to prepping the engine bay for the braking fabrication and start working on mounts. Hoping to have her up and running come spring!
            1987 325i-M60b44 swap
            • Zacm829
              • Jan 2008
              • 1919
              Got a little bit done this past week. We are making some progress but also planning for the more involved stages of the swap.
              First I had to get the car transported from Charlotte to Dk's shop in Columbia. Even got a save the Tatas truck!
              Did some basic dis-assembly before Matt got home. Euro bumpers are so easy to take off!
              Next we worked on making the radiator core support removable which is something that I have wanted to do for years. Highly recommend.
              So much room to yank the old busted m20 out! Also started shaving unnecessary brackets to clean up the bay.
              Next we need to make the brackets to reattach the core support, also started mocking up the braking setup and needing to make a couple brackets and spacers for that.
              Custom brackets/engine mounts coming right up!
              • Holland
                • Nov 2008
                • 7209
                White Alpinas, yes please!
                Originally posted by DEV0 E30
                • irrelevante30
                  • Apr 2013
                  • 100
                  sub'd
                  • Zacm829
                    • Jan 2008
                    • 1919
                    Heading down to work on the car this week. Possibly get the braking setup all sorted and mounted. Work has been slow due to some winter weather in SC.
                    • whysimon
                      • Jan 2007
                      • 663
                      Zac,
                      Really cool what you're doing here. I've got something in the works as well. It should be an interesting spring brodeo.
                      • Ether-D
                        • Sep 2011
                        • 2838
                        Originally posted by whysimon
                        Zac,
                        Yes it will. Looking fresh brosephs.
                        Originally posted by Andy.B
                        I was born on 3/25…
                        • agent
                          Vice Grand Pubaa
                          • 7960
                          Matt's dog is enormous.
                          Originally posted by kronus
                          • Batz
                            • Aug 2013
                            • 303
                            Looks great so far! Keep it up. Subed
                            • Zacm829
                              • Jan 2008
                              • 1919
                              Had some free time to get some work done.
                              Got the brake booster relocation finalized and finished. Being able to make custom brackets makes life so much easier!
                              • MonkeyMadness
                                • 3251
                                I take it you check fitted the engine with your set up. For some reason it looks set pretty far back. I put mine as far forward as i could. I was afraid of hitting the valve cover. It looks good. Keep it up!
                                Sent from my LG-LS970 using Tapatalk
