Running an M60 Without a BMW
  • Vtec?lol
    • Dec 2009
    • 3278
    Yes the sensor is required. Running the engine without it will fault the ecu as it needs to sense speed in order to properly calculate load. It will run lean without it or fault and run rich.
    From what I understand with my swap, the speedometer gets the speed signal straight from the diff and the ECU gets the signal from the speedo. I'm not sure if the signal is changed from the speedo.
