Will be checking out an 04 gto this week for my swap
  • papag1234
    • Feb 2012
    • 297
    I'll be checking out a running 04 gto for it's motor/trans sometime this week. I think that I've previously read somewhere that some parts (bell housing?) will not work in the e30... Anyone know what I'm talking about?
    What I'll be taking from the car:
    Motor with all accessories
    Trans
    Wiring Harness
    PCM
    What else should I look into snagging from this gto?
  • MattAvino
    • Jan 2011
    • 2147
    Is the car wrecked?
    E30 buildy things
    http://www.r3vlimited.com/board/showthread.php?t=195286
    • papag1234
      • Feb 2012
      • 297
      100% running and in great condition
      • Madhatter
        • Oct 2004
        • 966
        Only difference on the T56's I can think of is they have the shifter in the rear position, as far back as it can go so it kinda hangs over the back of the gearbox. Not a problem though as you can just change the shift position with another shifter as the boxes use a rail setup so you can install them in a few different positions.
        Just a little project im working on
        - http://www.lse30.com -
        • papag1234
          • Feb 2012
          • 297
          Okay thanks for the info. This is probably what I read about. Should I take the driveshaft too?
          • Madhatter
            • Oct 2004
            • 966
            you'll need the yoke at the least, so, yeah.
            • alco
              • Feb 2013
              • 197
              Will this help?
              Velocity Motor Works
              1972 2002
              1983 533is
              1987 325is (Roxanne)
              1988 M6
              1989 M3
              1989 325ix (Darth Maul)
              Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
              • papag1234
                • Feb 2012
                • 297
                Thanks for the replies fellas. I left the guy a deposit. Should have everything by next weekend or maybe sooner.
