LS Swap guide
    Will the F body shifter not bolt onto the GTO trans, putting it in the same position? Because it looks like it would.
      Yes, the fbody shifter will fit no problems
      E30-LS1 aka. 357is
      email us to pick up our LS1 swap guide
      E30-LS1 KITS now available!!
      E30LS1@gmail.com
      e30ls1.com
        say what now?
        Looks like the GTO shifter sits too far back so the shop that did my swap put in an fbody style shifter. STIFF AS FOOOOK
          I have the MGW in mine, too. It's nice but very stiff for sure!
            I have a GTO trans in mine. F-body shifter will bolt up but you also need the F-body shifter cup or it won't line up properly.
              I hear long shift knobs can cure 'stiff' shifts. Just finished making this a few hours ago:
              Measured at 8.75". Used some scrap purpleheart wood that a friend had laying around. Still have to drill the hole a bit deeper - hitting my hands on it while turning in 1st, 2nd and kinda in 3rd. I will say though - shifting is a blast now. Super easy to tell which gear you're in and to shift you only have to move your hand a few inches from the steering wheel.
                I'd be worried about the wood cracking but I have that same idea. I'll just pick something up from autozone.
                  As long as the hole you drilled is properly sized there shouldn't be a problem with the wood cracking. If you do end up making something out of wood (which I recommend, because wood is baller) do yourself a favor and get a wood that isn't super dense. Took me about 6 hours of filing to get a 2"x2" down to that shape. Wood was so dense/stringy that trying to use a carver/blade would throw it off and that was with my press set at the lowest speed.
                    Any chance some one who has GVS kit can take a picture of the transmission mount bolted on their car?
                    Worlds 1st LS powered e30 cabby.
                    Cab
                    billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                    Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
                    Shaggin Wagon
                    : 01 325xiT 5 speed
                    91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                    88 CRX OEM+ 42mpg DD.
                      What throttle cable is used with nonDBW LS motors?
                      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                        I'm not sure as I'm a DBW setup. Find out for me :)
                          How bad is the DBW lag? Did you already flash the pcm to remove it?
                          Also, get on Sikky about getting your car ready for this year.
                            The lag isn't really there. I haven't driven it much but I haven't noticed a difference. I might just be lazy and leave it like that honestly. I kinda like the gas pedal this way.
                            My car is back home. I'm doing all the left over bits to get it ready.
                              What is everyone running for a fuel pump? I've herd that the oem pump is good for 400
                              Cab
                              Shaggin Wagon
                              : 01 325xiT 5 speed
                                I use a walbro 255. I put down 400wtq and over 500whp with my last motor. Should be fine for the LS.
