Sikky E30 LS swap kit group buy
  • Zach33
    • Jan 2014
    • 43
    #106
    I have it on there now, but not sure what I'll end up with. I have an IX booster and I've been playing with the thought of using that. I don't have ABS and don't have high beam headlight, so I may have room to fit everything with a little modification of the current setup which is supposed to use the Mustang hydroboost. Once I get the engine in I'll know for sure, but the headlight/ABS delete isn't an option for everyone.
    Picture below sort of what I was thinking early on. That is the stock booster, IX booster is a little smaller but not much.
    • shiboujin
      • Feb 2006
      • 2791
      #107
      Sorry I dropped the ball on the pictures. here's a ton! Note the final headers are V-band unlike mine
      • jalopi
        • 2370
        #108
        Jeez, how slammed is your car Yoshi? Was the oval exhaust pipe really necessary? Or are we just being cautious? Regardless though... very well done
        • shiboujin
          • Feb 2006
          • 2791
          #109
          I forget. I think it's a 4 inch oval into 3 inch straight back. maybe it was a 5 oval with a 4 inch straight back. It's just a tight fit down there. I'm not really that low at all really.
          • jalopi
            • 2370
            #110
            Hm. Just ordered parts to make a real exhaust for my car - hopefully 2.5" (single pipe) isn't too restrictive.
            • shiboujin
              • Feb 2006
              • 2791
              #111
              For what motor? I think that's too small. IMO 3 inch.
              • CLM21
                • Dec 2013
                • 223
                #112
                Was that as big as you can fit down there? Im going HCI LS3, is there really even enough room for a big enough exhaust? A single 3" out isnt going to cut it.
                • jalopi
                  • 2370
                  #113
                  ford 302. I was the guy whose exhaust was dumping in front of the front tires at summit in october.
                  hopefully it's not too restrictive.... I used this site to figure out my exhaust size:
                  I'm guestimating I'm making 300-320 wheel, so per the calculator I'm a bit undersized - hopefully it won't make too much of a difference.
                  • shiboujin
                    • Feb 2006
                    • 2791
                    #114
                    LS anything will put out 350 wheel I would assume. I'm not so great on these motors yet though. I'd do a single 3 but that's tough. dual 2.5s would be awesome. I hate doing dual pipes though. So much welding.
                    • shiboujin
                      • Feb 2006
                      • 2791
                      #115
                      We have 4 confirmed!
                      • Zach33
                        • Jan 2014
                        • 43
                        #116
                        LS1 = 350 hp
                        LS2 = 400 hp
                        LS3 = 430 hp
                        LS6 = 405 hp
                        LS7 = 505 hp
                        LS9 = 638 hp
                        All CRANK numbers. Most of the above have variations in hp depending on application.
                        I'm not an LS expert, just wikipedia'd it.
                        aaaaaand bump for the last buyer....
                        • CLM21
                          • Dec 2013
                          • 223
                          #117
                          Nice, so only 1 more for 10% off..... I know someone wants a LS powered e30.
                          And yup ^^ those numbers are right on. Some applications have different intake manifolds or air intakes so some vary +/- 10ish hp. HCI ls3 will put me somewhere around 550-600 to the crank. I don't think a single 3 is going to cut it. Is dual 2.5s even possible?
                          • DJP215
                            • Nov 2013
                            • 35
                            #118
                            Im going to run 3" true duals. Ill make them fit somehow.
                            • CLM21
                              • Dec 2013
                              • 223
                              #119
                              Haha. Well, thats my goal. I just didnt think it was possible.
                              • DJP215
                                • Nov 2013
                                • 35
                                #120
                                Everythings possible!
