Sikky E30 LS swap kit group buy
  • shiboujin
    • Feb 2006
    • 2791
    #121
    Stock is close to 2.5 in some spots so I don't see why not. I think the hard part is making it around the subframe. I think that's the lowest part in the rear of the car.
    Cooome oooon 1 more!
    • Zach33
      • Jan 2014
      • 43
      #122
      Question bump:
      Should I consider a driveshaft hoop for the aluminum shaft?
      • shiboujin
        • Feb 2006
        • 2791
        #123
        Like the kind to prevent it from spearing you in the leg if it breaks? I mean... wouldn't hurt. I don't think it's necessary. I'm not going to.
        • Zach33
          • Jan 2014
          • 43
          #124
          Also thinking of catapulting. I'll just treat it like everything else... meh, it'll be fine.
          • Zach33
            • Jan 2014
            • 43
            #125
            Another brake booster option, similar to what I'm thinking - 540i remote brake booster. Only problem with the brake booster up front is the reservoir ends up underneath the high beam headlight or right up against it. This one has the reservoir relocated so you can easily fill it, may even allow room for ABS.
            • Zach33
              • Jan 2014
              • 43
              #126
              Another shot:
              • LSM3
                • May 2012
                • 340
                #127
                Kit looks good. Couple of observations/comments. .
                Dont forget to weld those support tabs for the motor mounts. Those mounts look unforgiving.
                Dual 2.5" drones like he'll (ask me how I know). A single 3" would be better. If you have the coin get oval exhaust. You will get a larger ID AND MORE ground clearance.
                Mounting a hydro boost on the firewall isn't that bad. Find a booster that fits, remove the pedal box and mod it to fit. Yes a remote vacuum system is easier but it does not look as good, is large and cumbersome and you are stuck using an oem master.
                • JGood
                  • Jan 2004
                  • 7959
                  #128
                  http://www.r3vlimited.com/board/show...225093&page=54
                  That's mine. The reservoir is actually in the factory location (for the car the remote booster came out of... e34/e32 m60 cars). The booster bracket has a spot where the reservoir clips on to. You might be able to fit the ABS unit up there somewhere, especially if you modified that tray next to the frame rail (you could cut it and drop it down a few inches). But it will be a very tight fit!
                  Honestly, it's pretty simple to get the e34 remote booster working in an e30 chassis. It's incredibly strong and reliable as well, I don't think I've ever seen an e32/e34 with any part of the remote linkage system fail. My car brakes 100% like a factory e30 with this setup. It's adjustable, uses OEM replaceable parts, looks factory, and really doesn't take up that much useful space. To me it was a no-brainer. But I also didn't have ABS...
                  e30 restoration and V8 swap
                  24 Hours of Lemons e30 build
                  • Zach33
                    • Jan 2014
                    • 43
                    #129
                    Cool thanks for the detailed pics!
                    • shiboujin
                      • Feb 2006
                      • 2791
                      #130
                      I wonder how much that strut tower reinforcement does and what cutting through it does.
                      • garretvs
                        • 464
                        #131
                        The hole shown is minor, and if there is an across-the-towers strut brace the small hole is a "nothing" for the chassis.
                        E30-LS1 aka. 357is
                        email us to pick up our LS1 swap guide
                        E30-LS1 KITS now available!!
                        E30LS1@gmail.com
                        e30ls1.com
                        • shiboujin
                          • Feb 2006
                          • 2791
                          #132
                          So strut bar mandatory if you do this?
                          • JGood
                            • Jan 2004
                            • 7959
                            #133
                            What are you referring to? I didn't really cut through it at all for the linkage rod. There was already a hole there, I just oval'd it out a bit for some piece of mind clearance. And the upper bar doesn't go through it at all, it just bolts to the plates that I welded on. Actually, with the addition of that upper bar, and of the plates to mount the bottom of the firewall bracket, it's probably significantly stronger then it was stock.
                            • andy_2123
                              • 16
                              #134
                              Really wish I could just buy the oil pan setup, I'm assuming a factory rack can be used with that pan?
                              • shiboujin
                                • Feb 2006
                                • 2791
                                #135
                                oh that top bit bolts TO it.
                                The oil pan requires an E36 rack. Factory E30 rack won't work for header clearance. I'll work for the oil pan clearance though.
