*Updated & only kinda shitty now!* The definitive 5.0/302 swap guide
Hey everyone. Just bought a daily so its E30v8 time. been eyeing this swap pretty much since i bought my e30 in Dec 2012. I purchased Nick_e30's full swap kit minus the drivetrain so i have the driveshaft, mounts, oil pan, MS w/harness, wideband, 540 booster (which is for sale), and several other odds and ends.
I've decided to go the Garagistic pedal box w/ wilwood pedals (Dual pedal triple master) route and i know ive read about people running dual 5/8 masters and 3/4 for the clutch but i was wondering if anyone could back that up?
i was also worried about the pull slave but now i know about the rosehill kit i will be purchasing that as well
A lot of very good info on this thread BTW.Comment
Hrm... maybe I'll look into ovalized tubing. The only exhaust of yours I saw was the Y-pipe, you used 2.5" pipe until the collector, right?
Also, delicious dude, yes get two 5/8" masters for the brakes and one 3/4" master for the clutch. You won't even notice you don't have a brake booster that way. Life in the e30 will be nice :)Comment
I am hearing about people always snapping axleshafts with 5.0 swaps. My friend has a s52 swap with mods and has no problems.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
garage queen 91 bmw 325is / 1972 Chevy El Camino 355 sbc 450hpComment
Ok you guys. I was doing some test fitting on my e30 today. First: what 5.0 oil pan are you guys using? Its obvious from what I noticed that it needs ro be a front sump pan. Also, sway bar or no sway bar for rear pan clearance? Second, can you guys post some pictures of how close is the front of the engine (accessories and serpentine belt to your radiator, and what radiator you guys used. Thanks a lot and cheersComment
I'll take a pic of the rad clearance when I get the chance, but
You need an old 70's mustang pan to modify. It is front sump
You need a front sump pickup tube
Sway bar can be kept just fine
I have almost no clearance between the WP snout and the rad, but I've got the Mishimoto z3m rad which is thick as fuck.Comment
