*Updated & only kinda shitty now!* The definitive 5.0/302 swap guide
Any progress with this? I have been trying a Volvo step-bore m/c that has a 5/8 smaller bore and it works well. It's designed to use the larger bore to move more fluid, then transitions to the 5/8 to provide enough pressure. The pedal travel is good but not perfect, but that may be my crappy bleeding procedure. I can lock up the tires and invoke the abs now, which I couldn't with the booster delete and stock m/c.Comment
So everyone goes for a hyd clutch setup?
My old setup was a cable so I'm halfway through modding my clutch pedal to suit cable clutch.Comment
yeh I always do stuff the hard way haha. But i figured I'd work with what i got.
When I gather up some coins I'll go Hydraulic with one of those nice pedal setups.Comment
true and I can get a cable the hyd clutch conversion done on the gearbox side as well but If I'm going to the effort of doing that I may as well go for a nice boosterless setup =)
Also another go question would be what accelerator cable is everyone using? I've done a universal 'speco' brand type but I'm not really liking it. Although my setup is carby so Its a bit different.Comment
I like it!
Problem with me is the Right Hand drive so I need a cable. Mine works but I just need to find something shorter than 1.5m so i don't get that (binding up) problem as well. M42 Would be too short I guess....
Very helpful thread guys, good stuff!Comment
