Your car looks really clean! Good progress so far.
My M60 swap
Thanks!
Started to do a compression check but it was around 2 am and I kept melting wires so I'll figure it out tomorrow..
Btw, does anyone know which wires go where to jump the starter?
Sent from my iPhone using Tapatalk - now Freesigpic'89 325i
M60 swap in progressComment
Ghetto is the name of the game! JK I'll give that a shot. I'll get a pic of the starter shortly
Ok I hooked power up the the red wire and the solid white wire. I had the body of the starter grounded and it spun while laying on the floor but when I bolted it up it wouldn't spin. Just the gear would engage
I found that I had to engage the bendix before hitting the motor solenoid for it to work. Could that be your issue?sigpic
Velocity Motor Works
1972 2002
1983 533is
1987 325is (Roxanne)
1988 M6
1989 M3
1989 325ix (Darth Maul)
Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...Comment
where in Raleigh are you? I'm in five points and would like to check it out sometime.
I think I met you at Oktoberfest. Something about a motor mount...?'87 325ic, powered by S50.Comment
I'm less than a mile from Rex hospital..lol yea that was me with the sheared mounts (still sheared) but yea you can certainly come check it out. I'm going to need the most help I can get with this project..
