Im starting to put together my 5.3 and im wondering what water pump everyone is running.. i was thinking 2010 camaro l99 pump it has same spacing as the truck pump so no need for spacers, like the f body pump needs. the outlet on the new camaro pump is on drivers side is that a problem? i will not be running a power steering pump so it will be a basic set up just a water pump and alternator... also whats a good rad to run with the ls motors?
LS guys what water pump and rad?
91 e30 318is M50 SOLD
http://www.r3vlimited.com/board/showthread.php?t=149570
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Tags: None -
Water pump? L92 truck pump.Im starting to put together my 5.3 and im wondering what water pump everyone is running.. i was thinking 2010 camaro l99 pump it has same spacing as the truck pump so no need for spacers, like the f body pump needs. the outlet on the new camaro pump is on drivers side is that a problem? i will not be running a power steering pump so it will be a basic set up just a water pump and alternator... also whats a good rad to run with the ls motors?
Rad? Mishimoto Z3M1985 M635csi Black on Buffalo
1985 535is Zinno on Black
1985 M635csi White on Pacific Blue
1988 M3 Lachssilber on Black (sold)
1987 M3 Zinno on Black (totaled) -
Left, L92 truck pump. middle, L99 camaro pump, right, LS2/3/7 from a C6 corvette.... if using the z3m rad would the l99 pump be better set up? should be closer to the rad inlet... or should the hose go up instead then turn around to go to the rad, seems like more work but maybe the l99 comes out and would be to close to the rad?
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Comment
the L99 camaro pump wont interfere with the intake?
Your pump should match your accessories so the pulleys are all aligned.95 7.1L 16V E36 M3
Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
LIKE my Facebook Page! CLICK HERE
from what i found the l99 2010 camaro pump fits under the ls1 intake on the 5.3 and yes it lines up so no need for 3/4" spacers like the old f-body pumps... I'm just wondering if with the hose going straight out if it will be to snug against the rad... it would be much closer to the rad pipe tho since it would be on drivers side... the pulley also is flat so its about 3/8ths farther from the rad vs the spaced out f-body pump and truck pump.
l99 pump...
92 325 vert project
l92 vs l99 pump..
probably run my belt like this.
92 325 vert project
You need way more wrap on the crankshaft and waterpump pulleys.
Edit: Something like this.
The way you have it setup now, the crankshaft will struggle to drive the accessories without slipping.Just a little project im working on
- http://www.lse30.com -Comment
ya i was thinking that people say it works but would be pushing it. this might be easy and a bit better.
i guess my main concern is how much space between the pump outlet and the big z3 rad... i can make the belt work one way or another...91 e30 318is M50 SOLD
92 325 vert project
I will be using the C7 vette pump for my ls1 swap using the z3m mish rad. I was playing with fitment yesterday (using Garrets kit) and the stock ls1 pump with the z3m rad interferes by about 1/16 of an inch. My next issue will be the top port on the rad being close to the power steering pump, but you wont have this issue so count yourself lucky lol.
As for port locations, it looks like if you can use the l99 pump, go for it. Makes it cleaner running the rad hose instead of having it between the pulley and the rad.
Here is the clearance I have with no water pump, use your judgement from the main pulley to the rad as clearance.
Takes a fair bit of horsepower to turn an alternator under load, waterpump too at high speed. The second pic has better wrap around the waterpump, but you should really aim to try and keep a similar amount of wrap as stock to avoid any problems, certainly don't want to run less than half the amount. It's easy to mount another pulley on the head like in the pic I posted.Just a little project im working on
yaa wont take much to make the belt work. having the outlet on that side must be better then squeezing the hose across between belts and rad.. even with the truck pump the points up instead straight out like the f body pump, it would still have to run past the belt/pulley because the intakes so low it wont have room to go over the pump. I'm going to try and get a 2010 pump Monday when i get my manifold gaskets.Takes a fair bit of horsepower to turn an alternator under load, waterpump too at high speed. The second pic has better wrap around the waterpump, but you should really aim to try and keep a similar amount of wrap as stock to avoid any problems, certainly don't want to run less than half the amount. It's easy to mount another pulley on the head like in the pic I posted.91 e30 318is M50 SOLD
92 325 vert project
LS2-7 water pump with the snout of the outlet cut off (leaving "short" bead on tube), with 5/16 pump spacers, 2x sets of pump gaskets. All with FBody FEAD (Front End Accessory Drive). Used CTS-V serpentine belt tensioner with a few washers behind it so it would line-up with the rest of the pulleys.E30-LS1 aka. 357is
email us to pick up our LS1 swap guide
E30-LS1 KITS now available!!
E30LS1@gmail.com
e30ls1.com
or you could buy something that fits direct and doesn't need all that stuff.Just a little project im working on
Ya l99 seems like the anwser... called around for one today just one place with aftermarket pump just under $400. So looks like ill have to order it online.91 e30 318is M50 SOLD
92 325 vert project
