what did the 5 speed that most people use come out of? i am having a lot of trouble finding one...
m60b40 e30 swap transmission help
From the research I've done, I believe its a 5 speed out of an E34 530i. Someone correct me if I'm wrong.Originally posted by 36bruaIsn't that what these forums are all about making stuff easier... OO no never mind this is r3v...
Instagram: @parkus08
91 BMW 325is ///M-Tech II
08 VW .:R32
04 Audi A4 Avant 1.8TQ
very helpful, thank you both. so can i pull a zf trans from any of these E34 E36 E46 Z3 328i M3 as the ebay add says? there are regularly bmws at the yard, i would rather pull one for $125 than pay 1600 for that one on ebay. is the bellhousing the same even though those are i6 and i will be using a v8?
Originally posted by MJCRO View PostCheck out car-part.com, I sourced mine from a junkyard on there for $200.
Found this listing on eBay (non-affiliated) explaining all the models that had it.
http://www.ebay.com/itm/REMAN-BMW-ZF...0f8ee2&vxp=mtr
That list isn't even remotely correct, that trans won't even bolt up to half of those cars.
There's two ZF310's that you'll likely come across. The 6 cyl version, and the 8 cyl version.
The internals and rear casing are the same for all ZF310's as far as I know, but the bell housing we need is v8-specific, which was only found on the e34 530i. Which isn't an issue, as 6 cyl ZF's tend to fetch more then the v8 ZF's. I found 2 or 3 at a local junkyard that charges $100 for a trans. I ended up paying $300 from another local junkyard that already had it pulled from the car, and could verify it only had 99k miles.
So, you need a ZF310 from an e34 530i. Nothing else will work.
Originally posted by JGood View PostThat list isn't even remotely correct, that trans won't even bolt up to half of those cars.
Just looked on the site now, there are over twenty of them under $500.
Originally posted by irrelevante30 View Poston what site?
You can definitely find them local too.
Originally posted by irrelevante30 View Postso this one http://www.ebay.com/itm/TRANSMISSION...11bb7c&vxp=mtr ?
