m60 Swap Question
  • Nygdup
    • Jul 2006
    • 418
    m60 Swap Question
    Looking at doing a m60 swap using the 530i transmission, and after doing a bit of searching I haven't come across any mention of what folks are using for driveshafts. Can someone clue me in what's the "go-to" solution now that this swap has been done so many times?
    Thanks, I'm sure to have more questions if this build comes to light.
  • JGood
    • Jan 2004
    • 7959
    E36 328i, e30 m3, late e30 325e will all work. You just need a stock length driveshaft that matches the 96/12mm guibo. Same deal as a 24v swap with a ZF.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • jip
      • Apr 2014
      • 5
      E36 328 driveshaft is pretty hard to get in Sweden (due to they are wanted by ppl running M50 Turbo in E30) I use a converter coupling together with original driveshaft - bolt on! From 3x96mm M12 to 3x78mm M10. I think revshift makes them in the US.
      BMW Alpina B3 3.0 -94
      BMW E30 V8 4.0 -86
      • LoneWolf
        • 402
        Would this adapt a 6-speed to an e30 driveshaft? I can't remember the size on those flanges
        • JGood
          • Jan 2004
          • 7959
          Nope.
          • Nygdup
            • Jul 2006
            • 418
            Sorry.. went AWOL for a bit.
            Thanks for the info guys. Exactly what I needed.
            • jip
              • Apr 2014
              • 5
              Don't think there are any 110mm -> 78mm flex disc adapters available from Revshifts.
              BMW E30 V8 4.0 -86
              • dirty30
                • 3013
                driveshaft has to be shortened regardless
