Denny's M62B44 swap (MS2 installed First start VIDEO inside)
    So i removed passenger side valve cover no damage... I was thinking can the Dual Mass Flywheel cause this problem??? Meantime i will continue to dig in engine...
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
      Not unless it blew up?
      Sent from my SM-N910P using Tapatalk
        Check the chain tensioner. If its bad it may be possible that the cams rolled far enough to have a valve smack a piston???
          updates?
            Originally posted by MonkeyMadness View Post
            updates?
            I removed the oil pan late last night and to my horror found the oil pump screen obstructed with very thin pieces of metal shavings bronze looking metal.and a small piece of timing chain plastic rail. I need to upload pics... Oil pump nut was tight... Now did enough pieces go in the pump to lock it down..?? I still need to remove the head on drivers side....but its not looking good at all..
            Denny
            ___________
            Blogs:
              Denny
              ___________
              Blogs:
                Denny
                ___________
                Blogs:
                  Yea not looking so hot. All that gold flake is bearing
                    Yep your probably right....only copper is the bearings... So now the mas scientist has to pull everything out and another long winter project starts again.... No warning nothing... Car ran like a beast...more i read on the m62 the more i want to join the LS darkside...
                    Denny
                    ___________
                    Blogs:
                      Nooooo find a doner m62 to swap in for now and build the block you have...
                        Your right man.....worked to hard to have this setup... Out looking for donor..stay tuned..time to come back stronger..better....faster...
                        Denny
                        ___________
                        Blogs:
                            Lolll... My favorite show of all times :)
                            Btw anybody know if the vanos can be disabled hardware wise...?... 90% of m62's for sale near me are vanos...
                            Denny
                            ___________
                            Blogs:
                              I would think so.
                                Hey Denny, sorry to see this, damn.
                                A quick search didn't show anything to disable Vanos. There are a few other things that changed along with Vanos being added. DBW throttle, water cooled alternator. I would look for a pre-vanos motor or M60.
                                Is this the first time you've had the lower pan off the motor? Did your oil pressure light not come on?
