stock brake booster relocated?
  • jalopi
    • 2370
    Yep that's the exact kit.
    Used this website to get the following figures:
    Our cars need about 3200 ft/lbs of braking torque to have "good performance" brakes. With the massive kit, stock hydraulics & all you're looking at about 865 ft/lbs with 70lbs of leg input.
    3/4" master will bump you up to 1246 ft/lbs.
    3/4" + e36 sized brakes will bump you up to 1865 ft/lbs
    3/4" + e46 330i sized brakes will get you up to 2524 ft/lbs
    5/8" + e46 330i sized brakes will finally net you 3635 ft/lbs of braking torque, though you really need a dual master system for a cylinder that small. Eventually this is what I'd like to do, make my pedal configuration not suck balls and gain an extra 1000 ft/lbs of braking power at the same time
    Also, running the lines isn't that hard, I'll take a picture of what I did if it stops raining sometime today.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      You realize that a dual master cuts your line pressure vs. pedal effort in half, right?
      • jalopi
        • 2370
        no, running two masters doesn't effect line pressure. dual master systems allow you to run smaller master cylinders (which effects line pressure & pedal effort) because they address the primary weakness of small MC's - not moving enough fluid. that and you gain the safety of having two brake circuits instead of one.
        an apples to apples comparison would be that if you had the same size master cylinders in a single and dual setup, lines pressures and pedal efforts would stay the same, but the amount of distance you have to push the pedal for the pads to make full contact with the rotors would be halved. this is the reason most dual setup guys can run 5/8" masters; us single setup guys would have an engagement point that's damn near at the floor, as e30_302 will attest to.
        so yeah, previous statement still stands. you should probably do your homework before you call people out in a rude way...
          • Jun 2010
          • 2796
          We're talking about dual MC's and a balance bar, right?
          If there is 100 lbs of load on the pedal and a 6:1 pedal ratio, there is 600# of force at the MC. On a single MC with 1 sq in of piston area, that makes 600 psi of line pressure. On a dual MC, each with 1 in^2 and the balance bar set 50/50, the same loads are spread across 2 in^2 of piston area and you get 300 psi of line pressure.
          Now if you're talking about a production style dual circuit MC, that's something else, but I didn't think that was the case due to the name "Wilwood" being thrown around.
          • e30_302
            • Sep 2013
            • 453
            You wanna try miserable, run a 1" dual bore Wilwood.
            • smalcol
              • Apr 2013
              • 70
              Wait, are some of you guys running a single circuit brake system now? That's a really bad idea. Seriously. There haven't been single circuit brakes in a BMW since what the mid 60's?
              • danval
                • Mar 2013
                • 191
                Has anybody tryed using 2 stock master cylinders and no booster? With their proportioning valves of course
                • e30_302
                  • Sep 2013
                  • 453
                  No one said it was a safe idea #YOLO
                  • jalopi
                    • 2370
                    • e30_302
                      • Sep 2013
                      • 453
                      LOL
                      It isn't smart though, I'm going to look into a dual circuit that's the right size.
                      • bmk
                        • Feb 2011
                        • 598
                        Did you get a chance to snap some pics?
                        Worlds 1st LS powered e30 cabby.
                        Cab
                        billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                        Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
                        Shaggin Wagon
                        : 01 325xiT 5 speed
                        91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                        88 CRX OEM+ 42mpg DD.
                        • Stvstr
                          • Dec 2013
                          • 82
                          Has anyone tried or looked at a step bore m/c that is designed to push a large volume of fluid at the start of the stroke then transition to a smaller bore to build appropriate pressure? 80's Volvos used one that has a 5/8 bore for the secondary.
                          I bought one to experiment but am having trouble deciding how to route the lines in an e30 so I may have to get a Volvo distribution block. Also I seem to have failed at bench bleeding the m/c as the pedal sinks to the floor even after bleeding all 4 calipers.
                          • e30_302
                            • Sep 2013
                            • 453
                            Update: Apparently the Porsche 914 master cylinder (dual circuit) has a 17mm (just slightly larger than 5/8") bore, and a mounting hole spacing close enough to make work. I think I'll have a go at it.
                            • jalopi
                              • 2370
                              The ones I found were expensive as fuck though
                              • e30_302
                                • Sep 2013
                                • 453
                                Yeah, gonna have to be patient on eBay.
