stock brake booster relocated?
  • danval
    • Mar 2013
    • 191
    has anybody relocated the stock M/C + Booster? I saw a video someone posted and it looks like the stock booster. Is there any info around? I looked but couldn't find much
    thanks
  • e30_302
    • Sep 2013
    • 453
    With the right setup, you won't miss the booster at all.
    • danval
      • Mar 2013
      • 191
      Meaning getting the righr pivot point on the pedal? Ive heard about the non booster setup, and changing the leverage pivot point on the pedal.
      • slammin.e28
        שמע ישראל
        • 12054
        Usually if it's a relocated booster it's the e34 V8 setup, not the stock e30 booster.
        That said, boosterless is the way to go. As said above, do it right and you won't miss the booster.
        • e30_302
          • Sep 2013
          • 453
          The right pivot point and most importantly, the right sized master cylinder.
          • slammin.e28
            שמע ישראל
            • 12054
            ^^ Just noticed you are in Staunton......and I don't think I know you.....
            • e30_302
              • Sep 2013
              • 453
              I'm an elusive creature. Also my car's not exactly street legal so she stays at home.
              • The Dark Side of Will
                • Jun 2010
                • 2796
                I live in NoVA and have a friend in Staunton.
                • jalopi
                  • 2370
                  Considering what you're swapping, a pedal box is gonna be your best bet.
                  Garagistic for the bracket, wilwood pedals, 2x 5/8" masters for the brakes and 1x 3/4" master for the clutch. All in all it's about $150 more than a Massive delete kit and the wilwood pedal setup e30v8 recommends, but you'll have brakes that REALLY work (price figure is with keeping the stock e30 brake master) and you won't have to deal with a penny's gap between the brake pedal pad and the clutch pedal pad.
                  • bmk
                    • Feb 2011
                    • 598
                    [QUOTE e30_302;4203139]The right pivot point and most importantly, the right sized master cylinder.[/QUOTE]
                    What is the right sized master? OEM or aftermarket? What's your set up?
                    Worlds 1st LS powered e30 cabby.
                    Cab
                    billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                    Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
                    Shaggin Wagon
                    : 01 325xiT 5 speed
                    91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                    88 CRX OEM+ 42mpg DD.
                    • jalopi
                      • 2370
                      Right size master is kinda dependent on what else you have. Me and 302 have pretty much the same setup, sans rear brakes, and my brakes feel like they're slightly improved vacuum assist stock brakes.
                      We both have a booster delete plate and a 3/4" wilwood master, part # 260-3374
                      If you have a pedal box you can use 5/8" masters since each master is only moving two sets of caliper pistons. Much more braking torque this way. part # 260-3372
                      You will hate life with the stock size master cylinder. Very little braking torque, extremely heavy pedal.
                      • bmk
                        • Feb 2011
                        • 598
                        Edit found it in another thread. Willwood 3/4
                        Same one? Fixed.
                        How would this work with stock brakes?
                        Cab
                        Shaggin Wagon
                        : 01 325xiT 5 speed
                        • jalopi
                          • 2370
                          Ebay link won't work. But it won't work with "stock" brakes, you'd still need a booster delete plate & increase your pedal ratio.
                          • bmk
                            • Feb 2011
                            • 598
                            Fixed the ebay link
                            Yeah I have the massive booster delete and the stock MC right now. It was just a pain to make the brake lines so switching out the master for another im sure require a whole new set of hard lines :/ Do you think that the 3/4 master is the best way to go for a stock brake system?
                            Cab
                            Shaggin Wagon
                            : 01 325xiT 5 speed
                            • e30_302
                              • Sep 2013
                              • 453
                              Use unions and short pieces of lines to connect to what you've got. The Wilwood is a single outlet, so you'll need to tee it to the fronts and rear.
