Fuel pump for LS1
  • 1owNslo
    • Apr 2012
    • 334
    Fuel pump for LS1
    What fuel pump are you LS1 e30'ers using? Mine will be a 427 stroker... itb's fat cam high flow heads... etc etc etc... just need a pump to supply the fuel. advice???
    10 minutes... then we invade China.
    We'll begin with the small town of General Tso's,
    And move to the Orange chicken province.
  • Gertech
    • Jul 2013
    • 180
    You'll probably need something more substantial than me, but I'm running a stocker in my '86 without any issues.
    • King Mufasa
      • Sep 2012
      • 530
      stock pump is fine, just the fuel pressure regulator should be the question. But don't know if stock FPR is fine..
      • 1owNslo
        • Apr 2012
        • 334
        any options tho for an upgraded pump?
        • e30_302
          • Sep 2013
          • 453
          Free Shipping - Aeromotive A1000 Fuel Pumps with qualifying orders of $109. Shop Fuel Pumps at Summit Racing.
          • Ryan1212
            • Oct 2012
            • 35
            I'm running an in-tank walbro 255 in mine. I currently have a bad vette fpr in it and see 75psi at the rail. Switching it out for some sort of aeromotive regulator next week.
            • _JohnnyD_
              • 215
              I found my BMW M60 runs much better with a Walbro 255 pump in place of the stock pump. After 30-60 min hard driving my car would stall due to lack of fuel pressure until the stock pump cooled.
              • 1owNslo
                • Apr 2012
                • 334
                with that aeromotive one replace the in tank pump? or is it just an additional one, kind of like a high pressure pump?
                • bmk
                  • Feb 2011
                  • 598
                  I will also be using the stock pump with a the Vette regulator/filter. Once the motor is broken in ill probably go with a Walbro 255 they cheap and near direct drop in for late models.
                  Worlds 1st LS powered e30 cabby.
                  Cab
                  billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                  Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
                  Shaggin Wagon
                  : 01 325xiT 5 speed
                  91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                  88 CRX OEM+ 42mpg DD.
                  • JGood
                    • Jan 2004
                    • 7959
                    Define hard driving. I've driven my m60b44 for 3-4 hours straight, never had an issue with my new OEM stock pump. However, I've never taken mine on a track where it would see constant full throttle for 30+ minutes. Just curious what conditions you were in when your stock pump overheated.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • 1owNslo
                      • Apr 2012
                      • 334
                      off topic... but i loved your build
                      • iansane
                        • 1342
                        If the thread starter is going to actually be running a 427 I really doubt a stock pump will be able to support it. Maybe I'm crazy.
                        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                        • The Dark Side of Will
                          • Jun 2010
                          • 2796
                          Depending on heads, that could be a 550 - 650+ HP engine.
                          • iansane
                            • 1342
                            If it's a build that supports itbs on an LSx then I would hope it to be well, well north of that or the intake setup is just wasted. I'd be thinking at the bare minimum the newer 340 walbro or dual 255s. Just my WAG. I run a racetronix pump on my turbo'd LSx with 60lb injectors and the most I've seen is somewhere around ~80% duty cycle. No dyno sheet to back it up though.
                            • shiboujin
                              • Feb 2006
                              • 2791
                              I have a walbro 255 with my LS2. no issues. Stock FPR isn't even an option.
