Spring rates with V8
  • kristov
    • 222
    Hi,
    What kind of spring rates are you guys running with the heavier V8s up front?
  • Red_liner740
    • Oct 2014
    • 127
    which v8? cuz that makes a huge difference in peoples answers.
    The BMW V8, the M60 is all alu and weighs 30lbs more than the M20 (give or take), due to the shorter design it actually sits further back than the I6's...so for all intents and purposes the weight gain is negligable.
    • Gertech
      • Jul 2013
      • 180
      I'm running 550 lb/in front, 700 lb/in rear GC coilovers in my LS swapped car. It's pretty stiff and not a daily driver. Rides surprisingly well for those rates though.
      • e30s50dan
        • Nov 2008
        • 2076
        ^^ Yea,but what size sway bars are you running
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • shiboujin
          • Feb 2006
          • 2791
          I'd imagine you'd want softer springs. Not by a huge amount though. All that weight is now behind the front suspension.
          I run 550/1000 (mimicking Jstock). I want to go probably 450/800. I'm LS2. I bet most people here want M60
          • jalopi
            • 2370
            I was rocking H&R races, not sure what those spring rates are. Apart from the rear being a little too gooey I thought the car was pretty sweet
            • Hooffenstein HD
              • Nov 2012
              • 1388
              I'm having a hard time believing that.
              • Red_liner740
                • Oct 2014
                • 127
                I did too, but I researched it and I can't quote and link now but those numbers came from people actually weighing their engines. It's on a bimmerforums topic. M20 came in at low 400s with all accessories while the m60 was closer to mid to high 400s.
                • jalopi
                  • 2370
                  I believe it. For some reason people think aluminum is this magical substance that's both 1/3 steel/iron's weight and only needs the same amount of material to be just as strong.
                  The reality is (we're comparing cast aluminum to cast iron here, nothing special going on, let's not nitpick about alloys) as a general rule, aluminum is about 1/2 as strong as iron. Manufacturers compensate for this (only when ultimate strength is needed... like when making an engine block) by using extra material. This can be in the form of thicker walls, extra webbing, ect.. you see where I'm going here. Basically, the end result is that cast aluminum parts are typically about 2/3rds the weight of their cast iron/steel counterparts, just as long as strength/longevity was a concern during design.
                  Add in all the extra bits - an extra head (both of which are wider), three extra cams, two extra rods & pistons, a (probably) heavier crankshaft, ect and it's easy to see how the m60 could weigh as much as the m20.
                  That being said though, I'm pretty skeptical that the m60 is heavier than an m20. I've seen a few m60 swapped cars in person and they're fairly compact... now if we were talking about something big and long like an LS then that's a different story
                  • kristov
                    • 222
                    It's an LS1.
                    Currently on H&R coilovers:
                    Front - 210 lb/in
                    Rear - 485 lb/in
                    The car feels sluggish and unpredictable in the corners. I would think the springs are way to soft for the heavy engine and transmission up front.
                    • shiboujin
                      • Feb 2006
                      • 2791
                      210? My dick is stiffer than that.
                      • Chris916
                        • 183
                        450/650 here with m60.
                        Very streetable and hold corners pretty good.
                        • LoneWolf
                          • 402
                          • kristov
                            • 222
                            Seems like it is time to try som stiffer springs.
                            • JGood
                              • Jan 2004
                              • 7959
                              I'm running 450/600 with 22/19mm bars, M3 front links. Koni S/A's. It's a daily driver, and I'm very pleased with the mix of firm ride and comfort. There's no body roll.
                              I weighed my car with an m20b27/g260, then an m50b25/g260, then an m60b40/zf320, then an m60b44/g420. Same car, same NHRA racetrack scale, across a ~5 year time span. The difference in engine weight is negligible IMO, but the supporting mods for the engine may impact overall weight more significantly (trans choice, huge radiator with lots of coolant, remote oil filters/coolers/extra oil, P/S and/or A/C delete, brake booster delete/relocate). In my case, it was less then 100lbs difference from m20/g260 to m62/g420. And most of that weight is in the trans, which was well worth it for the extra gear, as a daily driver. All of the weight gain was between the axles, down low. I've been driving this exact car for 13 years and over 200k miles, I would notice a difference in handling and/or suspension characteristics if it exists. I did not.
                              Throwing a 180lb passenger in the seat next to me makes a noticeable difference. The V8 does not.
                              YMMV.
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
