topless 5.3 project
  • 1991 e30 bmw 318is
    • 523
    topless 5.3 project
    guess its time to start a thread for my project. 92 vert...2002 lm7 5.3, with a few little extras. nv3500 5 speed. i have been gathering up parts all summer, i hope to have it running in the spring.
    what it looked like when i bought it, last year. all stock, new soft top. Florida car.
    m20 pulled and sold last week.
    test fit my z3 rack hope my stock airbag shaft works out...
    all cleaned up and primed
    91 e30 318is M50 SOLD
    http://www.r3vlimited.com/board/showthread.php?t=149570
    92 325 vert project
    http://www.r3vlimited.com/board/showthread.php?t=341370
  • shiboujin
    • Feb 2006
    • 2791
    What research have you done for the LS swap? The knuckle will be too thick and you don't have clearance to the header.
      • 523
      I did a little bit. I know most cars have more bulk on the shaft then mine. It also is a direct fit to the z3 rack so I was hoping it would work...I do not have headers yet. So im not sure what ill go with for them yet...
      92 325 vert project
      • shiboujin
        • Feb 2006
        • 2791
        Originally posted by 1991 e30 bmw 318is
        ...have more bulk on the shaft then mine.
        Headers will need to match the mounts. You'll have to do some welding perhaps. I'm a rep from sikky and can help you with anything on that kit if you are interested. I'm reasonably sure that even if the headers clear, you'll likely melt that rubber flex disk. That's even best case scenario.
        PM me if you want help. But yea. Sikky ftw.
          • 523
          I have garrets mounts. I tryed to buy sikky but would not sell to me unless I got the complete kit. Not sure if sikky headers would work with garrets mounts. Also thought of making my own headers. ...
          92 325 vert project
          • shiboujin
            • Feb 2006
            • 2791
            They can't guarantee fitment unless it's 100% their kit so they won't sell it separately. It's a business tactic. The full kit just saves you time and R&D. Anyone can really make mounts. The great fitting headers on the other hand are super hard.
            • Denny
              • Jan 2010
              • 822
              another canadian vert getting a v8 :)
              Denny
              ___________
              1990 BMW red 325IC M30B35 all stock Girlfriends ride
              1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
              Blogs:
              http://bmw325e30.blogspot.com/ (restoration)
              http://bmw325e30turbo.blogspot.com (Twincharge M20)
              http://bmw325e30m62b44.blogspot.ca/
                • 523
                wont melt now... see what i can do for headers when i get it in there i guess...
                92 325 vert project
                • shiboujin
                  • Feb 2006
                  • 2791
                  haha that does indeed work!
                  • bmk
                    • Feb 2011
                    • 598
                    Woohoo another LS powered vert!
                    Worlds 1st LS powered e30 cabby.
                    Cab
                    billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                    Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
                    Shaggin Wagon
                    : 01 325xiT 5 speed
                    91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                    88 CRX OEM+ 42mpg DD.
                      • 523
                      painted with trunk textured paint...
                      92 325 vert project
                        • 523
                        car now has 3 pedals....
                        all bushings and mounts,,, 3.73lsd to replace open 4.11
                        braided lines installed and wheel studs,
                        92 325 vert project
                          • 523
                          installed my Torquer V2 on 112, comp cams rocker upgrade, psi valve springs, checked for push rod length. have to order them tomorrow.
                          home made valve spring tool. made with big washer a nut and bar. used water pump bolt to hold it on. works great. just bring the piston up top so the valve can only fall down so far.
                          engine upside down for cam swap to keep lifters from falling down
                          92 325 vert project
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5234
                            Steering feel with a solid flex disc is unreal. I think you'll enjoy it.
                            Originally posted by priapism
                            Originally posted by shameson
                            • Q8y_drifter
                              • Aug 2009
                              • 297
                              subbed!
                              Alpine White 1989 E30 Coupe - LS1/T56
