LS1 Swap Rear end options
  • Ryan1212
    • Oct 2012
    • 35
    Originally posted by jalopi
    FWIW i've heard that the stock gas tank is superior to most fuel cell setups as it doesn't really suffer from starvation like alot of 'murican cars do AND it effectively raises the center of gravity of the car. gas is, like, 8lbs per gallon, so... math
    in any case, i'd just use the stock fuel tank. odds are BMW spent alot more money in keeping that shit more puncture/flame resistant than any aftermarket company did throughout their entire lineup
    A surge tank solves the fuel issue very efficiently. You can run one with the stock tank or a cell. I am mainly getting rid of my tank because my driveshaft was super close to the gas tank and I had to space it down with 4 washers on each bolt to gain enough clearance to not rub (using the adapter from jagsthatrun). This winter I am installing the rear camber correction and raising the subframe so all even more reasons to get rid of the tank being in the way (also leaves space for routing awesome exhaust exits through the side rockers).
    • bmk
      • Feb 2011
      • 598
      I have some weird heavy vibration from somewhere in my drive line above 120. it really freaking annoying I think my diff is ever so slightly crooked or something. I had to go with a custom drive shaft because I was afraid of it hitting the gas tank.
      Worlds 1st LS powered e30 cabby.
      Cab
      billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
      Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
      Shaggin Wagon
      : 01 325xiT 5 speed
      91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
      88 CRX OEM+ 42mpg DD.
      • e30_302
        • Sep 2013
        • 453
        Do not do that. The rocker panels are very structurally necessary and significant, do not cut into them. Run it under them if that's what you want.
        • iflytii
          • Jun 2004
          • 482
          Yep, good advice. We will run them through the rockers on our race cars only because those cars are extensively caged. Even then we still reinforce the area around where we cut for the pass-thru.
          I've not had any clearance issues with a 3" drive shaft, or dual exhaust with a stock fuel tank. I've had starvation issues when low on fuel with a stock tank, but there are ways to remedy that. I'm hoping the Holly hydramat might be another good solution starvation as well. If you haven't seen this stuff, check it out: https://www.youtube.com/watch?v=N_jsSPRUTSA
          • The Dark Side of Will
            • Jun 2010
            • 2796
            6 lbs per gallon.
            Water is 8 lbs/gal.
            • kristov
              • 222
              Originally posted by iflytii
              No issues with the 188 diff in my car but I have twisted a couple cv joints into submission.
              For the tach setting, it's pretty straight forward. I invested in a HP Tuners license so I could continually make tweaks, but any good tuner can do this. For the specific settings it is documented well here:
              http://www.hptuners.com/forum/showth...t=tach+setting
              That looks like the smaller half shafts (318i, 320i etc.) and they break very easily.
              • TeXJ
                • 1914
                Equivalent in what way? Gasoline and water are two entirely different chemical compounds. They have dissimilar physical and chemical properties because, well, they are different. Perhaps you are referring specifically to the weight of a gallon of each. If so, then the weight of a gallon of each substance is not equivalent because the gas is less dense than water, so a gallon of water weighs more. When referring to volume, a gallon of gas is equivalent to a gallon of water. Even a gallon of oxygen is equivalent to a gallon of water, in reference to volume. However, when dealing with gases, pressure, temperature, and the number of molecules of the gas must be taken into account.
                Ok so I learned something today
                1990 325is
                m52b28
                3.73lsd
                g260 (1987 325is 5spd tranny)
                • jalopi
                  • 2370
                  Originally posted by The Dark Side of Will
                  6 lbs per gallon.
                  Water is 8 lbs/gal.
                  • Ryan1212
                    • Oct 2012
                    • 35
                    I more so meant through the actual side of the car like this, called it the rocker because well close enough. The sheet metal there isn't doing anything to help.
                    Obviously the bottom rocker rail/pinch welded area is structural, and my cage is going to basically attached above and below the 2 cuts for the exhaust.
                    Also, gasoline is about 6lb/US gallon, it's mass is about 0.75x the mass of water, hence why gasoline separates and floats on water.
                    • jalopi
                      • 2370
                      oh i believe you, i just don't like dark very much
