I'm in the process of gathering everything to do an m60 swap in my e30. I've been doing a ton of research, and JGood has helped me out quite a bit, but I don't want to bug just him...lol (Sorry about that Justin).
I picked up a 160k m62b44 and 6 speed from an e39 with hopes of doing an obd1 conversion and dropping it in, but, upon dropping the oil pan to replace the gasket, I found bits of timing chain guides in the bottom, so...guess its time to replace and potentially upgrade.
What I'm wondering is, is buying a replacement m62 single chain replacement set for $550 a good way to go, or should I go junkyard scrounging and try to find all the pieces for a double chain swap? Will the m62 single chain timing gears bolt to the m60b40 heads?
I'd love to do the double chain swap, but, the thought of pulling apart an m60 in the junkyard isn't high on my list of things I want to do, and its quite expensive to buy that stuff new. But mostly, that crank bolt being pulled in a junkyard just doesn't sound like a good time.
Next is head gaskets. Since I'm planning on swapping the m60b40 heads on to the m62 block, do I buy m62 head gaskets to fit the bore properly? Or should I buy m60 head gaskets? I'd like to do the head gaskets regardless since I didn't get a chance to compression test it, so, once again, kind of a while you're in there, might as well upgrade.
I already have all the supporting parts, such as engine mount arms, modified exhaust manifolds, modified trans mount brace, 6 spd driveshaft, wilwood manual brake pedal setup, remote mount oil filter housing (m62 came with it), etc...
just waiting on the engine itself, really. I've even contemplated finding a strong running m60b40 and just dropping that it, but I'd rather get the most out of it all at once and not pull it down the road for more power.
Opinions are welcome.
Sorry for the novel. Thanks guys!
