Cheap is a relative term. If you penny pinch, you can do the swap for super cheap. Truck motor, fab parts, etc. But a good base LS motor with almost no fuss isn't cheap at all.
'89 316i E30 LS1 Swap Build Thread
LOL
I would've gone with a 5.3 if it was actually cheaper. I picked up the cutty's 2003 LS1, the 4L65E, full accessories and a 0411 PCM for about $550 total, while a bare bone Gen III 5.3 long block is about $1000 if you're lucky.Alpine White 1989 E30 Coupe - LS1/T56Comment
Did you communicate this problem (collector being to long) with Sikky?They technically fit. However to fish the driver's side in between the engine and frame was probably the most difficult part of this swap. Passenger side slides in no problem whatsoever. Drivers side I had to
Massage the shock tower support
Remove valve coils, valve cover and plugs
Loosen engine mounts and pull/tilt engine towards passenger side.
They barely squeezed in with a lot of swearing, hammering and twisting.
The collectors will need to be cut/shortened if you actually wanna drive this thing on a road. They are too long and extend right towards the ground.
I ask because i had the same issue and they sent me 4 sets of headers before i finally gave up and modified a set. Sikky acted surprised and as if i was the only one to ever pitch a fit over fitment or lack there of./// E92 335i Msport FBO + Meth /// E70 X5 4.8i /// E30 325is LSX Swapped /// E30 325ix ///Comment
My Garage
09 Mini Cooper S (Daily)
09 E92 335i Msport
09 E70 X5 4.8
88 325es - Build Thread - http://www.r3vlimited.com/board/showthread.php?t=383423
87 325i m50 swap
87 325esComment
Nope never spoke with them after I placed my order. Wouldn't have helped much as I'm across the pond and shipping them back would be a hassle to say the least.Did you communicate this problem (collector being to long) with Sikky?
I ask because i had the same issue and they sent me 4 sets of headers before i finally gave up and modified a set. Sikky acted surprised and as if i was the only one to ever pitch a fit over fitment or lack there of.Alpine White 1989 E30 Coupe - LS1/T56Comment
The final design did change to incorporate a v-band flange, but the collector sticks out for no reason IMO. The primaries merge right where they meet so I don't really see the reason for that additional 6-7" inches of pipe.
Mine are also vband. I called and pitched a fit... They tried to help but sent 4 sets that did not work. I was refunded for the headers after i had to modify them. I'm not complaining because they handled the situation however, when spending good money on "quality" parts, this shouldn't be a issue.My Garage
09 E92 335i Msport
09 E70 X5 4.8
87 325i m50 swap
87 325esComment
Apologies, i do not know why it posted a link and not a open file...
My Garage
09 E92 335i Msport
09 E70 X5 4.8
87 325i m50 swap
87 325esComment
