Any updates???
'89 316i E30 LS1 Swap Build Thread
-Christian
Originally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list. -
Yeah sorry about that I've been meaning to update this thread since forever.
So far I've installed
- Remote oil filter setup with modified hoses and fittings
- All new SS braided power steering lines
- Radiator/hoses/fan/overflow
- Intake pipe and filter
- All the brake and clutch reservoirs and hoses
- All new 3/8" steel fuel tubing and hoses with a new 255lph walbro in-tank pump and rerouted the vent line to the gas cap.
- Reinstalled the dashboard with all the gauges, ignition switch panel and kill switch wired up
- Wired up 95% of the engine and ECU harness. Finishing up the fuel pump and fan relays
- Relocated the battery to the trunk (stock was mounted upfront)
I'm hoping I can get all the electrics done by tomorrow and hopefully have the ECU unlocked and ready before the weekend for its first start up.
I did discover a major leak from the clutch slave which will require me to pull the transmission out though. That's gonna be a major PITA.
The pic below is all I have for now I'll get updated pics tomorrow.
Alpine White 1989 E30 Coupe - LS1/T56Comment
That sucks! I had the same thing happen during my truck build. Had to pull the cab and basically blow the whole thing apart to get at it ugh.-Christian
Originally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list.Comment
sub'd currently doing the same swap in my 89 325is, im using the sikky kit as well but i will be going with the sikky hydroboost setup. we'll see how it goes!Comment
First start up video
Last edited by Q8y_drifter; 03-30-2017, 02:21 PM.Alpine White 1989 E30 Coupe - LS1/T56Comment
Real easy. Buy a standalone harness. Read instructions. Wire it up. Start it up.Alpine White 1989 E30 Coupe - LS1/T56Comment
Still got a ton of cleaning and tidying up to do but it starts and idles so that's good.Alpine White 1989 E30 Coupe - LS1/T56Comment
Start up video posted a couple days back
