regular old m60 swap
  • dothadance
    • Jun 2011
    • 1121
    #226
    Clutch line in the house! Went with the chase bays line through neue motorsports in an effort to reduce the chance of leaks and flare errors. Seems to be high quality and it even came with adapters. Ordered a custom length and it's at my door a week later!
    Customer service is on point!
    • dothadance
      • Jun 2011
      • 1121
      #227
      Clutch line is fully installed and ready for shifting!
      Also a little non v8 modification, picked up this airbag knee panel a few years back and I finally got around to messing with it.
      Step 1 cut a hole
      Step 2 insert light of one's choosing (pretty sure this is an e34 vanity mirror light?)
      Step 3 profit!
      (Will insert picture when wired in)
      This light fits OK. The spot I chose has a little too much curve so the bezel sticks out a little, but all in all the whole thing shouldnt be visible so I'm not too worried. If I were to do it again I would probably choose a smaller light.
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #228
        Not a bad idea! One of those, and another under the glove box, would really help throw some light down in the interior and make it less dim, giving it a slightly more "modern" look.
        • dothadance
          • Jun 2011
          • 1121
          #229
          That's the idea! Can't take credit for it however, I think it was the member gluklich or something that I stole it from.
          • dothadance
            • Jun 2011
            • 1121
            #230
            New front rotors. Hopefully she'll stop when I put my foot on that pedal!
            I'd like to rebuild my calipers too because I know there has to be some funky shit back there. When I bled my brakes a little more than a year ago I used an empty coke bottle to pour all the old fluid into, and by the time I was done it looked like it was a new bottle of soda. Who knows how long that fluid was in there for, at least 6 or 7 years...
            • dothadance
              • Jun 2011
              • 1121
              #231
              I've officially lost momentum... But hopefully I will be finishing up my exhaust on sunday!
              • jpod999
                • Dec 2015
                • 1401
                #232
                So close though!
                OBDI M62B44/6 swap
                Transaction feedback
                - jpod999
                • dothadance
                  • Jun 2011
                  • 1121
                  #233
                  Originally posted by jpod999
                  So close though!
                  Lmao, yeah man tell me about it. Pelican sent me a bad tps so I'm waiting on that to come in
                  Idle to wot is supposed to be 1k-4k ohms
                  • 36brua
                    • 689
                    #234
                    Remember your original inspiration for the project.
                    You will be glad you did... I am :D
                    My CA legal M60 swap
                    The happening in our garage
                    • dothadance
                      • Jun 2011
                      • 1121
                      #235
                      Yeah I'm really hoping this new tps and finishing my exhaust and getting my o2 sensors plugged in she'll fire right up. We will see though. Really, once I finish the exhaust I'll probably start hammering away again if it doesn't fire.
                      • dothadance
                        • Jun 2011
                        • 1121
                        #236
                        New tps is in and is within spec 👍
                        • dothadance
                          • Jun 2011
                          • 1121
                          #237
                          Stomp test still doesn't work. Fml
                          • dothadance
                            • Jun 2011
                            • 1121
                            #238
                            Just bought this bad bitch
                            95 nissan hardbody
                            2.4l L4 12 valve w/ 5 speed.
                            • dothadance
                              • Jun 2011
                              • 1121
                              #239
                              Haven't touched my car in a month or so. But a late night thought, do I need to modify my automatic trans harness at all? It doesn't seem like it, but if so would that cause a no start issue? I get to borrow my friends welder so I'm going to start goofing off with my exhaust again and hopefully mounting it up.
                              • marshallnoise
                                • Sep 2013
                                • 3148
                                #240
                                I can't remember, did you replace the throttle arm bushings? You might not be getting full blade opening.
                                Si vis pacem, para bellum.
                                New Hawtness: 1995 540i/6 Claptrap
                                Defunct too: Cirrusblau m30 Project
                                Defunct (sold): Alta Vista
                                79 Bronco SHTF Build
