regular old m60 swap
  • george graves
    • 19997
    #391
    Somehow I didn't sub to this???? .
    Originally posted by Matt-B
    • dasmanschaft012
      • Apr 2014
      • 642
      #392
      Drain the oil, make sure it looks ok.
      I have the cam timing tool set if u wanna borrow it.
      We're in deep now boys
      1988 325i SETA - Daily driver
      1988 340iL - Track car
      My M60 V8 swap thread here
      [oo==OO==oo]
      • dothadance
        • Jun 2011
        • 1121
        #393
        Originally posted by judgefargo
        Man, I just wanted to say I admire you deeply.
        I have literally read through your entire Thread this instant, for I am about to embark on a E30 M6X SWAP and am absorbing all the information I can get.
        I do hope I get to see this Project finished and hear your opinion on the difference from your stock car to now... heheeee I'm sure you will have a massive grin on your face when this happens and you write down a reply, for that is the whole reason of doing such a project.
        Funny enough I wanted to buy a 240Z, but due to the prices nowadays I chose to go the route of the E30 V8.
        I wish you the best, and keep at it in life and in your hobbies, for sooner or later they will be hard to differentiate, for you will be so used to putting in much effort and not giving up, that all will seem simple when thinking about it for a moment.
        Drive safe, and an my grandmother used to say, keep your pecker up!
        I'm glad you've found some inspiration from my thread as I have in so many others. This really is the last big hurdle, and having dealt with so many issues and done all the work myself or with my friends I'd hate to have to take it into a shop. Feel free to pm with any questions if you need anything.
        Sent from my SAMSUNG-SM-J327A using Tapatalk
        • parkerbink
          • Jun 2004
          • 10138
          #394
          Just read the entire thread, I'm tired just from the read.
          Great perseverance!
          Good luck.
          • dothadance
            • Jun 2011
            • 1121
            #395
            Got a thing in the mail today.
            Went to check my timing, ended up spending 2 hours trying to figure out where my timing mark is on the lower cover. It looks like it got filed off or something.
            .....Unless I'm looking at a non existent mark....
            • dasmanschaft012
              • Apr 2014
              • 642
              #396
              [oo==OO==oo]
              • dothadance
                • Jun 2011
                • 1121
                #397
                Originally posted by dasmanschaft012
                Lmfao, thank you.
                • wworm
                  • Dec 2016
                  • 1719
                  #398
                  lol I spent way too much time looking at google image searches trying to find the marks.
                  1984 Delphin 318i 2 door
                  • dothadance
                    • Jun 2011
                    • 1121
                    #399
                    glad i'm not the only one haha
                    • dothadance
                      • Jun 2011
                      • 1121
                      #400
                      Engine is officially timed properly. Driver side sprocket was off 1 tooth, compression is up slightly, 130-140psi. cylinders are all up atleast 10 psi, not as much as i would have liked. Put some fresh gas and new spark plugs, seems to be running better. i bought a leakdown test kit from harbor freight, so that will happen sometime this week. Main things left, coolant leak at back of motor, exhaust leak, and bleed the last little bit of air out of my clutch.
                      • dothadance
                        • Jun 2011
                        • 1121
                        #401
                        did some work yesterday. My coolant gauge wasn't working, so i swapped the plugs around. Voila! coolant gauge works and engine responds a little bit better. but it still bogs when the accelerator is hit, and after engine braking depressing the clutch the engine would die. took it for a quick test drive, and shes absolutely gutless. Roll her back home and me and a couple buddies racked our brains for a few minutes, checked the tps, good, unplugged the maf, little to no change.
                        No fucking way was i buying a new maf.
                        There wasn't really enough change to pinpoint it as the maf. For some reason i remembered a spece30 thread talking about ecu's and how there have been 10hp differences just by switching ecu's. this means nothing to me because my car is shit at this point, but i figured, fuck it i'll plug in my other ecu.
                        Here's the good news
                        Starts up nice... so far so good. Idles nice... so far so good. Blip the throttle.... ROARS TO LIFE... so far so good.
                        NIGHT AND DAY DIFFERENCE. As it turns out, the third ecu i bought and paid extra for, (because i thought my cheaper second ecu was potentially bad) was garbage. and the ecu i thought was bad, IS GOOD!!
                        Needless to say tires were roasted shortly after.
                        Didn't do anything on my "final checklist", but it fucking runs so nice now.
                        • The Dark Side of Will
                          • Jun 2010
                          • 2796
                          #402
                          Congrats!
                          • dothadance
                            • Jun 2011
                            • 1121
                            #403
                            Knocking stuff off my to do list. Fixed one of two coolant leaks, soldered starter wires, cut my hood to clear my coolant res stuff, messed with my shifter, looking for an early model shift plate so it wont hit the driveshaft anymore.
                            And i noticed that when my accelerator pedal is all the way down i still have about 1/4 throttle at the throttle body. Extremely excited about this seeing as i thought it was fucking ridiculous already, now i find out i still have 25% more throttle. fucked. Trying to keep up this momentum and start driving this upcoming week.
                            • dasmanschaft012
                              • Apr 2014
                              • 642
                              #404
                              i have a shift plate i’ll sell ya
                              [oo==OO==oo]
                              • dothadance
                                • Jun 2011
                                • 1121
                                #405
                                yes pls, pm'd
