Most apartments here start bitching the second the car is on jacks. Can't even get away with an oil change at most places. Your lucky indeed
regular old m60 swap
damn that sucks. i guess austin is pretty relaxed, because my car was up on jacks more often then not at my last apartment hahahaComment
also, i am in the market for an engine harness. if anyone has one or has any leads feel free to shoot me a pm.Comment
Clutch came in :D hopefully this thing lasts(ebay special, fx stage 1), seems like some people have had good luck while others not so much. maintenance items should be in later today too!
Also, should I use these pilot/release bearings that came with the kit or order new OEM ones? or not even worry about it and start slapping stuff together?Last edited by dothadance; 09-10-2015, 07:11 AM.Comment
I really wish I got a bigger box for how much money I spent lmao.
plugs, w/p, thermostat housing, thermostat, gaskets galore.Last edited by dothadance; 09-10-2015, 07:14 AM.Comment
Had some free time yesterday, so I did some guy stuff.
Got my oil pan off a few days ago and gave it to my buddy to modify. Also spent some time last night getting my brakes and throttle set up. No pictures of that though.Comment
Test fit. Going to lower the pedals a smidge, and I still need to grind/file the Wilwood assembly for my throttle linkage.
Picked up 10ft of copper/nickel tubing on the old grocery getter. Going to try and keep my ABS.
And I got my pan back!
she's a beauty!Last edited by dothadance; 09-17-2015, 08:41 AM.Comment
pan looks good. I suggest doing a leak test for at least 24 hr. trust me on this !!Comment
So i removed the two lines that went to the old m/c from the abs pump and have since realized I have no clue as to which line was for my front and which one is for my rear brakes.
Or if it even works like that! I'm hoping that it does (so I can set the bias bar appropriately)... Abs delete and booster deletes are pretty common, but I can't seem to find any info on the garagistic delete and keeping abs If anyone has any info, lemme know. I'll keep looking.Comment
yes. any liquid. low viscosity oil - used is ok ,or just water.
My fabricator has a lot of experience welded in/out and we ended up with a pin hole. Which became obvious after engine was in car and running....Comment
I have this set up w/ ABS. just make sure the bias bar is neutral ( equal f//r). I set pedal ht to full ht keeping full thread engagement of slave cyl push rod in clevis. adjustment once installed is next to impossible. Are you keeping the stk 'proportioning' valve to rear brakes ? At the least you may want to add a BBK kit on the front.So i removed the two lines that went to the old m/c from the abs pump and have since realized I have no clue as to which line was for my front and which one is for my rear brakes.
