regular old m60 swap
  • ncrmtrsprtsE30
    • May 2015
    • 204
    #181
    thank god you took out that ASC...
    BTW that 318ti will work with the Z3 short shifter as well.. thats the shift rod i used with my 6 speed trans and z3 short shifter.
    The "Because Race Car" M60 V8 Build Thread
    On Instagram Straight Flexin' #BecauseRaceCar
    • dothadance
      • Jun 2011
      • 1121
      #182
      Coming up empty looking for these starter wires. Haven't looked for the black/green wire but as far as the black/yellow I have one coming from the x20 one going to the driver side bank and one wire going to the diagnostic port.
      I have no wires going down to the starter. Would tapping into one of those wires be a bad idea?
      • jpod999
        • Dec 2015
        • 1401
        #183
        The one going into the drivers side bank doesn't go down to the starter?
        OBDI M62B44/6 swap
        Transaction feedback
        - jpod999
        • dothadance
          • Jun 2011
          • 1121
          #184
          Nope not from what I found. There's a wire for the alt and oil filter. Maybe it got snipped. I'll sniff around some more tomorrow.
          • dothadance
            • Jun 2011
            • 1121
            #185
            Suhhweeeet. Found both wires. They go to this strange connector and they both looked like plain black wires from all they crud that was caked on.
            Gonna cut the connector and fish these back over to the passenger side.
            • WYZEUP
              • Jun 2015
              • 105
              #186
              The starter motor has its own loom that plug into that plug so shouldn't need to cut wires as those wires should run through both looms
              • dothadance
                • Jun 2011
                • 1121
                #187
                Meh, I just chopped it off and crimped on some ring terminals. If I come across it in the future I might fix it. Thannks for the info though.
                • dothadance
                  • Jun 2011
                  • 1121
                  #188
                  Few pictures of my friends e36. He partially made this build possible.
                  • dothadance
                    • Jun 2011
                    • 1121
                    #189
                    Also, I felt a little saucy before work so this happened.
                    Sorry, we couldn’t find that page
                    NOTHING CAUGHT FIRE! Lmao
                    i was determined to try and fire it up before I had to leave for work and by the time I finished up I only had 5 minutes left to connect my battery and try it. Plugged the positive on fine, but as soon as I grabbed the negative I started shaking... I'm confident in my abilities and the work I've done, but I'm not sure if I have reason to be. So all I could think about was melting my harness, or something catching on fire, or to have absolutely nothing happen when I turn the key. Finally slapped it down and my trunk lights came on. So far so good. Walked to the drivers side and sat down, stabbed the key in the ignition and held on for dear life. Sure enough noises were made! But she wouldn't fire... What did I do wrong? Time for work.
                    All day at work all I could do was wonder, "what happened?" I mean, I'm stoked I got that much, but goddamnit I wanted her to run. Couldn't think of anything all day. I was going to check for everything in the morning, but as soon as I lay down to sleep I realize I was in such a rush to finish today that I swapped the fuel hoses around! She's not getting any gas!!! Hopefully tomorrow's the big day.
                    • delamaize
                      • Nov 2013
                      • 1453
                      #190
                      I hope you're able to get it to fire tomorrow man. I'm getting closer every day myself....
                      Dumpster Fire Pilot
                      • dothadance
                        • Jun 2011
                        • 1121
                        #191
                        Figured out I'm not getting any fuel whatsoever.
                        Now we get to play the game of finding out if its my pump or my wiring.
                        • dothadance
                          • Jun 2011
                          • 1121
                          #192
                          Also, if someone could help me figure out what this little terminal is that would be killer.
                          Ground? 12v? It exits at the passenger rear of the motor.
                          • marshallnoise
                            • Sep 2013
                            • 3148
                            #193
                            I can tell you that it is wrapped up on all m60 e34 cars and unused. I don't know what it is for, but from the factory it is just sitting there on the frame rail doing nothing.
                            Sent from my Z958 using Tapatalk
                            Si vis pacem, para bellum.
                            New Hawtness: 1995 540i/6 Claptrap
                            Defunct too: Cirrusblau m30 Project
                            Defunct (sold): Alta Vista
                            79 Bronco SHTF Build
                            • dothadance
                              • Jun 2011
                              • 1121
                              #194
                              Sweet. Couldn't find anything on it so I figured it was just another unused connector. Thanks.
                              • dothadance
                                • Jun 2011
                                • 1121
                                #195
                                Good news is my pump is good so I don't have to buy another one. Bad news is its not getting 12v. Bleh.
