LS Swap won't start
  • Pootis
    • 636
    LS Swap won't start
    Hi all. Dealing with an issue with my Ls swap. The car won't start the starter engages but won't spin. I checked the battery and it is good installed a new starter still the same thing hooked up extra grounds tried jumping it and it still does the same thing I had my old starter tested and had no issues as well. What could it be? Any insight would be helpful
    1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
    COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
  • flyboyx
    • 8371
    simple solution: change engine to m60 and she will start right up!
    Gigitty Gigitty!!!!
    • delamaize
      • Nov 2013
      • 1460
      this. lol
      Dumpster Fire Pilot
      • z28
        • Oct 2014
        • 362
        Does the motor turn over by hand?
        First e30 - 1991 318i 4 door
        • evl325
          • Aug 2009
          • 8
          Spin it buy had first
          • lemansguy
            • Nov 2013
            • 205
            stock flywheel and clutch setup? what trans? i cant remember if the LS1 uses shims for the starter or not, but the starter may be too close to the flywheel so they are binding, preventing the motor from turning over.
            '87 BMW 325i - ground control c/o, condor bushings, 16x8/16x9 wheels - SOLD
            '09 MazdaSpeed 3 - FOR SALE
            • Pootis
              • 636
              Motor turns by hand freely it is a truck starter with an ls7 flywheel. I'm going manually jump the starter and see if the bmw ignition switch is not sending enough amps and if that doesn't work I will shim it
              • lemansguy
                • Nov 2013
                • 205
                yea if the motor turns by hand, and the starter works when bench testing, sounds to me it has to be a bad engagement of the starter and flywheel.
                • iansane
                  • 1342
                  How is your starter circuit wired?
                  84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                  • Reyhan335
                    • Nov 2015
                    • 700
                    any update on this? has it started yet?
                    god i know that's a bad feeling you're so close
                    e30Ls1 Swap IG: 1dirty30
                    • Pootis
                      • 636
                      Yeah I am an idiot didn't have it wired correctly. It turns over but the ECU I was told had VATS removed does not so I should be getting it back tonight finishing up the exhaust and hopefully it is on the ground this weekend.
