M60 O2 sensor wiring
  • delamaize
    • Nov 2013
    • 1460
    Could I get someone with a M60 swap, or a M60 harness to confirm what wires go where on the o2 sensors? I think I may have mine wired up wrong, which is what might be causing my CEL for those. I am having a hell of a time finding a wiring diagram that shows what I'm looking for. I have 2 white, grey and black on the sensors, I know that the white wires are for the heater. The question is which color is suppose to be going to the other 2.
    Dumpster Fire Pilot
  • 36brua
    • 689
    Arent there any connectors on the harness or o2 sensors?
    My harness has a small tag on the sheath for the right/ pass side o2 sensor
    Did you try swapping connectors L/R ? Clean connectors ?
    I had chk eng lt from this also
    My CA legal M60 swap
    The happening in our garage
    • delamaize
      • Nov 2013
      • 1460
      My harness had the plugs cut off it, when the lazy fuck that removed the cats at the junk yard choose to cut them instead of unplugging them. I know which one is left and right, what I'm thinking now is I may have the actual 2 wires that go to the sensor portion backwards. I know I have the heaters right, but I am not sure with the other 2 wires. I don't want to risk swapping them, and having something fry because of it, assuming they are right now.
      I guess what I'm asking is which color wire hooks to the grey wire on the sensor, and which one hooks to the black. I know the whites are for the heater.
      Dumpster Fire Pilot
      • 36brua
        • 689
        ooo no connectors that's helpfull..
        my harness o2 connector are blk/yellow so blk/blk grey/yellow.
        1993 740i... section 1362 eng control pg 1362-05 or PDF pg 135
        hope this helps
        • delamaize
          • Nov 2013
          • 1460
          hope this helps
          Well, my black and yellow wires were backwards.
          I cleared the codes, and it's still throwing 1221 and 1212. Not sure what to check next....
          Dumpster Fire Pilot
          • 36brua
            • 689
            I will chk connectors this weekend to confirm my wiring
