Got my ECU all mounted up. It actually bolted up to the factory Motronic mounts and fit with some minor cover/glovebox trimming. Enough real estate under the cover for my bluetooth adapter as well.
Got my passenger side header squared away. It's from a 5th gen Camaro shorty set. One runner took a little massaging for the frame rail clearance but it was pretty minor. Exhaust should be finished up this weekend.
Intake pipe and coolant tank finished up. Had to use OE style hose clamps since everything is so narrow.
Lower radiator hose setup. 135 degree silicone bend, 1.5 u bend, 1.5 straight coupler
Bent up some hardlines for most of the trans cooler run. Way cheaper than AN hose.
