92 Mtech vert LS daily driver swap
  • jon volk
    • Dec 2004
    • 524
    #31
    Got my ECU all mounted up. It actually bolted up to the factory Motronic mounts and fit with some minor cover/glovebox trimming. Enough real estate under the cover for my bluetooth adapter as well.
    Got my passenger side header squared away. It's from a 5th gen Camaro shorty set. One runner took a little massaging for the frame rail clearance but it was pretty minor. Exhaust should be finished up this weekend.
    Intake pipe and coolant tank finished up. Had to use OE style hose clamps since everything is so narrow.
    Lower radiator hose setup. 135 degree silicone bend, 1.5 u bend, 1.5 straight coupler
    Bent up some hardlines for most of the trans cooler run. Way cheaper than AN hose.
    '92 MTech cabrio: Tesla P85 powered
    IG: telsa_bimmer
    '95 Alpine M3 5.3 LS, Precision 7675, TH400/Gear Vendors OD
    10.4@136 pump gas at 3530lbs. (SOLD)
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5548
      #32
      Lovin that expansion tank.
      Also, you have the right idea for what a DD should be about
      • lemansguy
        • Nov 2013
        • 205
        #33
        love what you are doing. I may be copying a couple areas of your build, keep up the good work!
        '87 BMW 325i - ground control c/o, condor bushings, 16x8/16x9 wheels - SOLD
        '09 MazdaSpeed 3 - FOR SALE
        • jon volk
          • Dec 2004
          • 524
          #34
          Tomorrow will be one month since I started. Getting to the final stretch. Filled the motor with oil. All the wiring, minus some battery power connections, is finished up. Just need to install my shift kit in the trans, source a 2.79LSD and install some hose clamps, air filter, trans cooler and radiator fan. Used an F-body power steering hose and just welded the banjo fitting off the old BMW hose. Finished up the exhaust as well.
          IG: telsa_bimmer
          • jon volk
            • Dec 2004
            • 524
            #35
            Fired it up on 7 coils today. Freshly motivated to finish the rest of little stuff. Trans is still empty so didn't let it run for more than a few seconds.
            Also took the M3 out for a rip today.
            IG: telsa_bimmer
            • Reyhan335
              • Nov 2015
              • 700
              #36
              damn man, beautiful build. love that you're going through it fast too! it's taking me forever :/
              e30Ls1 Swap IG: 1dirty30
              • jon volk
                • Dec 2004
                • 524
                #37
                Thanks. Patience isn't really my thing. I think I finished my M3 in 12 weeks and that was with all the turbo stuff. I keep looking at my final checklist and keep asking "that's it?". It's been awhile since I built something simple like this. Probably would even be a week or two ahead if I didn't have to mess around with making my own mounts.
                IG: telsa_bimmer
                • jon volk
                  • Dec 2004
                  • 524
                  #38
                  Pretty much a diff, driveshaft, silicone coupler and throttle cable away from doing burnouts. Topped all the fluids off and let it run for an hour or so. Didn't get over 186 holding the motor at 4k rpm for awhile. No higher than 181 at idle. Just running the stock radiator with a 16" Spal pusher.
                  Can't wait to get it back on the road every day.
                  IG: telsa_bimmer
                  • flyboyx
                    • 8371
                    #39
                    I'm impressed with your welding ability.
                    Gigitty Gigitty!!!!
                    • jon volk
                      • Dec 2004
                      • 524
                      #40
                      Got ahold of a 2.79 open diff for $50. I was going to weld it, but saw there were ebay knock offs of the Phantom Grip style "lsd" conversions and picked one up for $55 shipped. I've used these before quite a few years back doing turbo MR2 spyders and nobody wanted to pony up for a Quiaife diff. They werent perfect, but they put the power down for cheap.
                      As long as I can get a customer's turbo M3 off my lift this weekend, I should be on the road sometime next week. Had to trim some hood bracing to clear the intake pipe but everything fits now.
                      IG: telsa_bimmer
                      • jon volk
                        • Dec 2004
                        • 524
                        #41
                        IG: telsa_bimmer
                        • bmk
                          • Feb 2011
                          • 598
                          #42
                          Im diggin the the intake set up. I need something like that I am getting major seat soak with mine currently
                          Worlds 1st LS powered e30 cabby.
                          Cab
                          billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                          Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
                          Shaggin Wagon
                          : 01 325xiT 5 speed
                          91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                          88 CRX OEM+ 42mpg DD.
                          • Reyhan335
                            • Nov 2015
                            • 700
                            #43
                            whered you get the piece that connects to the throttle body
                            • jon volk
                              • Dec 2004
                              • 524
                              #44
                              Ebay
                              Powerdyne supercharger elbow
                              IG: telsa_bimmer
                              • jpod999
                                • Dec 2015
                                • 1401
                                #45
                                Also bought a Powerdyne blower inlet to use as a throttle body elbow. Its 3.5" in/out and just over 3" tall. I needed something super tight due to the added intake length of the nitrous plate.
                                OBDI M62B44/6 swap
                                Transaction feedback
                                - jpod999
