M60/62 ecu cooling fan
  • Zacm829
    • Jan 2008
    • 1919
    Has anyone had to install a fan in the glove box to cool the ecu? I've had a few issues when running the car extremely hard that the car cuts off and the ecu is abnormally hot.
    Two of these instances where on the track in 90 plus degree ambient temperatures. I know the e39 cars ran an ecu fan. I plan on just mounting a 12v dc computer fan to circulate cabin air. I've tried two different ecus with both experiencing the same issue. Engine cuts off and won't restart until ecu has cooled down to the point that it is warm to the touch.
    Let me know you're thoughts.
    Thanks in advance.
    Sent from my LG-H900 using Tapatalk
    1987 325i-M60b44 swap
  • delamaize
    • Nov 2013
    • 1453
    I have had the same thought. Although I have not had issues yet. I also have not mounted my DMU, it's just sitting in the glove box, I think that may be an contributing factor to the temp staying down.
    I'm also M60, not M62, and I'm running a 404 DMU
    Dumpster Fire Pilot
    • Zacm829
      • Jan 2008
      • 1919
      I have the same issues with the ecu mounted and with it just sitting in the globe box. Hoping that simply blowing cabin air across it will solve this issue.
      • dougie30
        • Apr 2012
        • 1708
        bumping an old thread, but my ecu gets wicked hot (hasnt shut off the engine yet) but i noticed when i touched it with my arm doing something in the glove box after like a 20 minute ride.
        im definitely going to run a little 12v fan probably for like a computer or something in the glove box. i was shocked how hot it gets.
        M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
        • Jean
          • 18228
          I don't remember as it's been so long , but thinking you'd want to ground the ecu chassis and that might help . Or mount the hole thing to a sheet of aluminum and ground that, would act as heat sink as well. My plan was to ground the ecu and add modify the stock fan ecu box to fit in the engine bay as I had battery there .
          • The Dark Side of Will
            • Jun 2010
            • 2796
            DO NOT GROUND the DME case.
            If you ground the DME case, then have a ground fault elsewhere, you can end up dumping ground current through the DME board to the case, which can release the smoke.
            • Jean
              • 18228
              The DME is mounted with metal brackets that touch it's case against the metal case of the e32/e34 DME/relay enclosure ...IIRC that box is then grounded to the chassis of the car.... but I would double check :)
                • Jun 2010
                • 2796
                Just like many things, it's a risk, not a certainty. Just be aware of the risk.
                • flyboyx
                  • 8371
                  it needs to be grounded. it came from the factory that way.
                  Gigitty Gigitty!!!!
