M60 Tach Signal Help - 85 325e
  • ArtFoodBMW
    • Feb 2014
    • 764
    I can't get my tachometer to work for the life of me.
    I have my tach signal noted as coming from Pin 14 from the X20 (Black and white wire)
    Connecting it to Pin 1 of the c104 is showing no response.
    My tach worked with its previous heart, and I tested with a different SI board showing no change.
    Anyone have any ideas?
  • jpod999
    • Dec 2015
    • 1401
    Are you using either a Dakota or the garagistic module wired in between the motor and the cluster?
    OBDI M62B44/6 swap
    Transaction feedback
    - jpod999
    • ArtFoodBMW
      • Feb 2014
      • 764
      I'm using the garagistic coding chip that replaces the normal 4cyl or 6cyl chip in the cluster. I should also note that switching that chip with an OEM one shows no change in tach performance.
      • sweet3
        • Oct 2012
        • 751
        Double check your pinout. I'm assuming you made your own adapter, right?
        PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
        • 36brua
          • 689
          Hi my car is an 86 pin out is
          X20 14 blk/white vehicle speed sensor vss. C101 14 added a pin and wired to yellow connector on cluster
          X20 20 blk TACH. TO C104 connector
          C104 to back of cluster blue terminal
          I wired the earlier garagistic 'doubler' in between c104 and tach with m 42 coding plug . I think the Dakota digital is an option
          My CA legal M60 swap
          The happening in our garage
          • ArtFoodBMW
            • Feb 2014
            • 764
            Figured it out.
            I was using pin 14, should have been using pin 20.
            My ETM for the engine harness claimed pin 14 was tachometer. But comparing other wiring guides (like m50 x20 outputs) the black wire from pin 20 is the tach signal.
            Further reason this makes sense: all wires on the e30 for tach signal are black.. which lines up with the also black x20 tach signal wire...
