m60 z3m coolant hoses
  • dougie30
    • Apr 2012
    • 1708
    Anyone have some info/ part number on coolant hoses they are running?
    Mostly the two front radiator hoses. I plan on looping the crossover pipe for now until the fall just to get the car down the road.
    Also I did a search and found the 20923 gates hose any confirmation on if that will work or not would be great.
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • JGood
    • Jan 2004
    • 7959
    I've been using a stock e36 325i lower hose and the Carquest 20923 upper hose for 5 years and 35k miles.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • dougie30
      • Apr 2012
      • 1708
      Thank you!
      Sent from my MotoG3 using Tapatalk
      • ArtFoodBMW
        • Feb 2014
        • 764
        I'm using all stock hoses, with the front two modified.
        Rear coolant bar hoses worked fine with slight trimming.
        Front lower hose is stock m60 with about 1-2" trimmed off the longer side
        Front upper hose is stock m60 with the middle cut out and a custom 1 1/2" steel U-bend, welded to make shape around the oil filter housing.
        • dougie30
          • Apr 2012
          • 1708
          Good to know the stock ones work as well, my oil filter is in a different location so no need for the "u".
          Also this was probably covered but could you just loop the rear coolant pipe outlet and run no heat?
          • ArtFoodBMW
            • Feb 2014
            • 764
            The only problem I see with looping the back rail is that's where coolant enters the system (at least in my case). Where would you fill the cooling system with coolant? Maybe you have a third nipple on the rear accumulator, which would work but mine only had two. One for coolant fill/heater inlet, and one for heater outlet.
            • dougie30
              • Apr 2012
              • 1708
              This is why i was asking, I didnt know this is where coolant entered the system
