M6x 5speed swap - E36 328 driveshaft question
  • Jean
    • 18228
    Hi,
    For those of you who've completed the swap using 5speed trans and e36 driveshaft with 4 bolt driveshaft side, can you please confirm if you were able to use the e36 328 driveshaft out of manual or automatic car?
    According to http://www.rtsauto.com/e30-bmw-m62-v8-swap-3/ manual driveshaft should be used, and some are saying one from automatic would work as well ?
    "The following is a list of suitable Drive shafts:
    M3 E30 (fits with 5-speed gearbox without modification)
    325e E30 fit 129PS (5 speed with no changes)
    E36 (medium stock exchange fits 328i, 5 speed with no changes)
    E28 535i (E30 rear of use, then like a wave M3 E30)"
    Thanks!
  • JGood
    • Jan 2004
    • 7959
    Yes, I used a 5 speed e36 328i driveshaft when I was still using the zf320.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • Jean
      • 18228
      Thanks! I did see your post :) There are more automatic driveshafts out there, any ideas if they are different length ?
      • dasmanschaft012
        • Apr 2014
        • 642
        I dont think an auto 328 works.
        I have a e36 m3 (manual?) that i did a quick measurement and i think will work. Haven't actually installed yet however
        We're in deep now boys
        1988 325i SETA - Daily driver
        1988 340iL - Track car
        My M60 V8 swap thread here
        [oo==OO==oo]
        • Jean
          • 18228
          Auto driveshaft is probably shorter right? Keep us updated with your progress !
          • DesertBMW
            • Aug 2011
            • 1042
            Auto driveshaft is much shorter than the manual one, but the rear section from Diff to center is the same length.
            • Jean
              • 18228
              Question - does anyone know for sure or have measured the rear section of the automatic vs. manual 328i driveshaft ? I know the front is different, but is the rear section the same on auto and manual ?
              • The Dark Side of Will
                • Jun 2010
                • 2796
                The CSB is in the same place on both, right?
