I'm having major issues bleeding my clutch if anyone has any insight. I exploded a slave today inside the bellhousing, I think from too much pressure in my Motive pressure bleeder. Theres no leaks, im on my second slave cylinder. I have basically 0 pedal pressure except the last ~2inches of pedal travel, it gets stiff. 2 person bleeding makes it worse (no pedal pressure at all). Prressure bleeding with the Motive gets me that little bit of pressure. The system seems to bleed ok visually, but I'm never getting any pedal pressure. I haven't found any leaks with the Garagistic pedal set up.
e34 530i 5 speed trans
ttv flywheel
Southbend S52 stage 2 clutch
Willwood 3/4" master
e34 530i slave
This is the last thing preventing me from doing a test drive.
ttv flywheel
e34 530i slave
