Manual sunroof - Syncing the crank assembly to the panel
  • Codym42
    • Mar 2013
    • 611
    On my '90 325i, I've noticed that the sunroof crank only makes the audible "click" when fully open or when vented up. Its hard to tell when its closed because it doesn't make the click when the sunroof reaches the closed position. I used the link below to remove the crank assembly and re-sync it.
    However, after following these instructions, it still doesn't seem right. It now clicks in the closed position and fully open but not in the vent position. I removed the crank assembly and spun it and it clicks every 18 turns. I guess my question is, should it make the click in all 3 positions (closed, open, and vent)?
    '90 325i - 5 speed coupe
    '05 330ci 6MT ZHP
  • glnr13
    • 1334
    i'll be watching this and have nothing to add other than when I first got my car the sunroof crank clicked for all 3 positions. Now mine is way out of sync and doesn't click at any position.
    • Codym42
      • Mar 2013
      • 611
      Well that's a bummer. I may need a new sunroof gear/transmission if that's the case.
      '05 330ci 6MT ZHP
      • zaq123
        • Jul 2016
        • 1550
        did you ever figured it out? assembling the car back and ran into the same issue
        • zaq123
          • Jul 2016
          • 1550
          can someone please confirm if it's supposed to click in all 3 positions or only 2? I synced mine and the handle only clicks in fully open and closed position. Not when in UP/Vent position. Anyone?
