A/C Spewing Freon out valve after recharge
  • AmosCake
    • Feb 2021
    • 218
    Tried recharging my ac but as soon as I take out the can from the valve, it starts spewing it back out? Or it could be oil/dye? Not sure why this is happening.
  • tomstin
    • Mar 2015
    • 568
    You probably need to replace the schrader valve core. You local auto parts store should be able to help you.
    2004 525i Manual - 1985 325E Coupe Manual
    • tyeler18
      • Jul 2019
      • 141
      The valves have a rubber seal in them that hardens and cracks with age. Vac it out, replace the valve (id do both) and vac/charge it again.
      • AmosCake
        • Feb 2021
        • 218
        Cool thanks guys
        • glnr13
          • 1334
          stupid question gets stupid answers but... are you recharging with r12 or did you update your system to r134a + appropriate seals etc?
          • AmosCake
            • Feb 2021
            • 218
            im going to convert to r134a but needed to fix that problem in order for the system to get evacuated
