New converted AC not cold enough
Good double check. It's the stock fan. Since I had to remount on the new condenser I just checked, it's pushing air in the right direction. Sent from my SM-G996U using TapatalkIs your auxiliary fan stock or aftermarket? When it comes on, does it blow the right way? When I installed my aftermarket, it came as a sucker, the directions had me reverse the blades AND reverse the wiring. I missed that second step, chased my tail for a very long time. About the 10th time I went through to verify EVERYTHING again I noticed the auxiliary fan was pulling air out versus pushing air through.'90 325isComment
Finally got around to checking discharge temp on my 12/88 production Touring.
After about 15 minutes it settled in at 47-48 degrees. Here's the fine print.
Ambient approx 78 degrees
Car was fully warmed up but had not been sitting in the sun
Fan speed 2
Recirc on
134a
Reading taken from center vent
Earlier this year I had the Seiko compressor rebuilt, upgraded the condenser and replaced all the lines under the hood, but did not touch anything inside the car.
Cory1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCAComment
I changed the expansion valve. I'm thinking it's something with the custom lines I had made, maybe? I dunno. It's cooling off here so I'll probably ignore it until April 2022. Sent from my SM-G996U using Tapatalk'90 325isComment
