e-brake stuck, help
  • viali8
    • Nov 2005
    • 673
    e-brake stuck, help
    My an 89 325i has been sitting for about a month. I went to move it the other day and the ebrake is stuck. I am able to get the ebrake handle down but the pads are locked up.
    Is there anyway of getting them "unstuck" with out taking off the calipers and rotors?
  • ethree
    • Aug 2007
    • 1216
    BFG, take the wheels off and give the hub a little tap tap taparoo! You might try using a torch to warm up the area as well.
    • viali8
      • Nov 2005
      • 673
      i know what a BFH what is a BFG..
      • xwill112x
        • Jan 2009
        • 4236
        put it in reverse and slip the clutch a little, that should jar it loose.
        • gearheadE30
          • Jun 2007
          • 3734
          If the pads are stuck that bad, its unlikely you'd be able to get the rotors off anyway. Try the clutch drop thing, but if that doesn't work, spraying some penetrating oil in there may be your best bet. You would need to take the rotors off and clean all of the oil out though, and maybe get new pads depending on how soaked they are. otherwise your ebrake won't have much holding power.
          Project M42 Turbo
          • viali8
            • Nov 2005
            • 673
            Its an autotragic :(
            thanks for the tips!
            • Naplm00
              • Nov 2008
              • 1573
              this happens on my dunebuggy often, i just get a few gus and try and rollit back and forth from the wheels while on the ground.
              This always frees it up
              88 325ic ~~~> Rusty and ugly
              85 E ~~~> RIP
              • asubimmer
                • 6482
                If you pulled the handle too hard then it could have pulled the cable out of the dust shield. Just something to look into...
                • viali8
                  • Nov 2005
                  • 673
                  i can actually move/drive the car but can hear/feel the shoes grinding.
                  • Leaf
                    • Apr 2009
                    • 985
                    Try a hard reverse, sometimes you hear a click or the sound of something clicking back into place when you do that.
                    Oh btw did the hammer trick do anything but fuck up your hub?
                    • viali8
                      • Nov 2005
                      • 673
                      i have not had a chance to look at it yet. weather has been miserable here. if anything i would hit it with a rubber malet.
                      • Naplm00
                        • Nov 2008
                        • 1573
                        the pad spreader components might also be rusted or seized into the open position, this happened to me
                        I just removed the rotor after alot of wiggling
                        and basted them with grease
                        85 E ~~~> RIP
                        • viali8
                          • Nov 2005
                          • 673
                          this makes sense. I will give it a go. thanks for the help
                          • Leaf
                            • Apr 2009
                            • 985
                            Also they might be just totally apart all together in the hub and little bits of them peaking out the backing plate rubbing against the rotor.
