I need some help with the window motor. Recently it stopped working. I checked the fuses, the connections, voltage and continuity. Went so far as to remove the motor, pull it apart, clean and reassemble. Now it works one direction. Is it possible that a diode or resister needs to be replaced? Has anyone else had the same issue and found a solution? Tried to buy a replacement but it is NLA.
1990 E30 Convertible drivers side window motor
Tags: None
Never had that problem on my cabrio, but a used motor should be easy to source. Just post a WTB ad here or on the r3v FB page. If the symptoms don't change with the replacement motor, you know the problem is something else.
Cory1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCA
