I dont know if it is called a hub, but my wheel will not fit over the inner circlular part where the center of the wheel is. They are Borbet type A and are perfectly round(the center "mounting" part) so i think that the center part on the car where it mounts is warped. What can I do to fix this? I have a parts car to get anything off of that I need. Is it a long job? Thanks
Wheel won't go on...
Did your car have aftermarket wheels on it before? If so, there is probably a plastic hub-centric ring on the hub that you need to pull off. If they were stock wheels before, then there is probably just some corrosion on the hub. If neither of those work, your $hit out of luck, because your new wheels have a hub bore that is too small.'91 318is
sigpic -
sounds good to me bro :up: ... but i gotta post it... 8)
-Pete
LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)Comment
agreed.Originally posted by m42technic"Angle grinder."
:shudders:
hope you don't get any vibrations...
lets see some pics.Comment
Oh good lord.Originally posted by bwanacbut dont the lug bolts hold the wheel on, so even if that center part was not there, it wold be fine? i dont think it is that bad.
Please, go look up "hubcentric", maybe that will help you a bit.
Angle grinder..jesus.
-CharlieSwing wild, brake later, don't apologize.
'89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.FYYFFComment
hahahaha... have you driven the car yet????
if not then go try it and tell us how that ass massage is....
for anything spinning as fast of a wheel of a car you cant exactilly take off much mass from anywhere with out making sure everything is balanced with out some serious vibrations... i hope for your sake that you didnt take off that muche30sport.net
'06 M3 Competition - 6-speed
'97 Range Rover VitesseComment
I don't see it as a matter of removing mass so much as a matter of allowing the wheel to not be centered. A little loss of mass that close to the center of the wheel won't matter nearly as much as having a wheel off center, and having the whole wheel mass be out of balance as a consequence of it's position.Originally posted by BeirBrennerE30hahahaha... have you driven the car yet????
for anything spinning as fast of a wheel of a car you cant exactilly take off much mass from anywhere with out making sure everything is balanced with out some serious vibrations... i hope for your sake that you didnt take off that muchComment
