Replacing the steering lock assembly
  • jsta1109
    • Jun 2015
    • 172
    Long story short the keyed section of the ignition switch was heavily worn and I've gone about replacing the complete steering lock assembly by purchasing the following part brand new 32-32-1-156-458
    Pictured is the damage to my steering lock assembly, this started as a 'trick' (pushing the key up as I turned) I had to do to start the car and eventually wore away enough to the point where the ignition would turn on but no start.
    Reassembly appears rather straight forward but I'm struggling with the spring and circlip. Beyond coming up with a tool to compress the spring while I install the circlip is there a glaringly obvious method that I'm missing here when it comes to reassembling the steering shaft?
    IG: https://www.instagram.com/josh.stacey/
    Flickr: https://www.flickr.com/photos/133952286@N03/
  • jsta1109
    • Jun 2015
    • 172
    Well ended up working this out.
    Purchased a steering wheel lock plate tool, Lisle 57340 and threw the smaller plate tool in the press so it was the same size as the spring. Compressed it all and installed the circlip.
    • Panici
      • Dec 2009
      • 2424
      Thanks for the update with the resolution.
      Helps when others have the issue in the future.
      '87 BMW E30 325is Turbo
      '98 BMW E36 328i
