Okay, what the hell. My car is haunted.
  • StereoInstaller1
    GAS
    • 22679
    Originally posted by mooseheadm5
    Start parasitic draw chasing with your ammeter. Most likely causes on an E30 are glove box light, trunk light, SI board, and any aftermarket accessories (radio, alarm.) Key off draw should be around 45mA tops. 400-800mA draw is usually a light bulb. 100-200 is usually something electronic.
    Agreed on all points, but I HIGHLY recommend using a testlight to start off with.
    Far easier to use than a DVM. Once you get to the acceptable range of only a tiny bit of light, then use the DVM.
    Closing SOON!
    Thanks for 10 years of fun!
      A test light will work, but a DMM isn't subjective or affected by ambient lighting levels.
      • kronus
        • Apr 2008
        • 13031
        I'm drawing about 90 mA at the moment, so it's a bit past the test light's capabilities.
        Looks like I blew my DMM's current fuse at some point, though. Damn.
        cars beep boop
        • mooseheadm5
          • Apr 2009
          • 375
          That may be why stereoinstaller uses a test light first. Anyhow, 90mA is not that much and really should not kill your battery quickly. How fast does the battery die? Are you checking this with the trunk light unplugged? Have you checked to see the draw with the trunk closed to check that drain?
          I hate test lights because you may think you are getting enough voltage somewhere because the light lights up, but without being able to quantify a voltage or current reading you can't be sure, so you go for the DMM anyhow. I skip the test light step, but I do have many uses for a self powered test light that is able to provide power or ground to a terminal at the push of a button.
          -P
          Moosehead Engineering
          • kronus
            • Apr 2008
            • 13031
            Yeah, I depress the trunk-closed-sensor when checking it. It's currently not bad, it was a lot worse before when the drain was up around 160 due to my old HU, and the car was standing in NJ... would die in about a week. It's not a problem now, I would just like to find the leaking component before it short-circuits completely on the inside and goes bad for reals.
            cars beep boop
            • Knockenwelle
              • Jul 2008
              • 395
              Test lights work great as a high-tech digital troubleshooting device.
              They're either on, or off. That's very useful, sometimes. Like "Is this circuit live, or not?"
              Start pulling fuses and watch the amperage draw.
              Mike
              '91 325i track car. Mostly...
              • accident
                • 7303
                i think it's time for a new E30. :P
                Moral of this story?
                • kronus
                  • Apr 2008
                  • 13031
                  For one of us ;)
                  Seriously, I think at this point you have every right to be mad at the police department and insco. It's been a month, wtf!
                  cars beep boop
                  • kronus
                    • Apr 2008
                    • 13031
                    Oh, I've done that already. It's the fuse with ALL interior accessories on it, 19, I think. The most fun one to fix :|
                    cars beep boop
                    • accident
                      • 7303
                      it's been well over a month. it was a month on the 28th of march. i got the report, faxed it in, they received it, and all of a sudden they want to talk to edwin.
